喂饱5870需要什么样的cpu?
发表于 2009-12-14 17:58:51
http://www.xbitlabs.com/articles/video/display/radeon-hd5870-cpu-scaling_10.html#sect0 数据不好转帖,自己去看吧,看得我头都大了。
ConclusionNow, I’ll try to sum everything up. First of all, the single Radeon HD 5870 does not depend as much on the CPU as it is supposed to. According to my tests (the left part of the diagrams), the Radeon HD 5870 is quite satisfied with an overclocked dual-core CPU manufactured two years ago. And you can even leave the CPU at its default frequency at the high-quality settings and 1920x1200. The only exceptions are Left 4 Dead and Warhammer 40000: Dawn of War II. The former game is not a problem for modern top-end Radeons while the latter, on the contrary, calls for a quad-core CPU, preferably from Intel.
The Radeon HD 5870 CrossFireX configuration is more CPU-dependent than the single such card. But it is not possible to say what CPU is sufficient for this graphics subsystem as this depends on the particular game, settings and resolutions. For example, at 1920x1200 with 4(8)x FSAA and 16x AF an Intel Core i7 at 2.67GHz is quite enough for S.T.A.L.K.E.R.: Clear Sky, Far Cry 2, BattleForge, Tom Clancy's H.A.W.X. and Resident Evil 5 as well as for Unigine Heaven Demo. In the other games and semi-synthetic benchmarks the Radeon HD 5870 tandem calls for a faster CPU. The question is whether you really need those 150-200 frames per second.
I also want to say a few words about the platform with the dual-core CPU as compared with the quad-core CPU. Winding up this test session I carried out an interesting experiment. I connected two system cases with a Radeon HD 5870, one with an Intel Core 2 Duo at 4.1GHz and another with an Intel Core i7 at 4.1GHz, simultaneously to the same monitor. Then I selected the most CPU-indifferent resolution of 1920x1200 with FSAA and AF and launched a few games. I switched between the two systems by choosing the input on the monitor (analog/DVI-I) and used two mice and two keyboards.
Using this setup, I could quickly switch from the system with a dual-core CPU to the system with a quad-core CPU and feel the difference between them in the same parts of five games. Excepting S.T.A.L.K.E.R.: Clear Sky, I easily felt the difference such games as Tom Clancy's H.A.W.X., Resident Evil 5, Call of Duty 5: World at War and Crysis. The gameplay was much smoother on the quad-core CPU, without occasional jerks as on the Core 2 Duo. Game levels were loaded faster, too. So, the numbers don’t always provide the full picture, yet I hope that this test session will help you decide what CPU you need for one or two Radeon HD 5870 cards.
发表于 2009-12-14 18:18:01
翻译:
现在总结一下,首先单卡5870不是那么需要很高的cpu。从作者左半边的数据来看,2年前的双核oc后表现也足矣,除生存之旅和战锤4w,甚至默认频率下表现也是不错。对于生存之旅而言对于高端雷龙不是问题,但对于战锤,intel的cpu表现更好一些。
5870cf相对单卡来说,对cpu的需求更多。但并不确定需要什么类型的,主频的cpu,这取决于在什么要求下跑某些游戏。例如,1920x1200 with 4(8)x FSAA and 16x AF , Intel Core i7 at 2.67GHz足以应付潜行者晴空,Far Cry 2, BattleForge, 鹰击长空,生化5 和Unigine Heaven Demo。在其他游戏中,甚至一些测试中需要更好的表现的话,则更需要更强的cpu。但,你真的需要每秒150到200帧吗?
作者还想说的一点在于双核平台和四合平台比较。作者的做了个有趣的实验,拿均是4.1G频率的酷睿双核和i7,同样的显示器和游戏运行要求下,除了潜行者晴空,其他游戏如鹰击长空,生化5,使命召唤5,孤岛危机 差别是显著的。游戏的流畅度、载入速度等均是四核占优。因此,无需太多数据,足以说明什么样的cpu更适合5870单卡甚至双卡。
发表于 2009-12-14 18:21:21
哎,潜行者晴空,3d-ray该淘汰了。这么多年了,还是换个新引擎吧,这个引擎的研发经费应该已经回本了,利润也应该赚得差不多了,这个引擎的寿命也该到头了,是该抛弃之,大幅改善或者开发全新的了。
发表于 2009-12-14 19:57:38
需要每秒150到200帧...
其实这个也不难 。。
找个CRT  把分辨率设置到800*600   随便怎么开特效
帧数都不会低:a184:
发表于 2009-12-14 21:12:54
游戏决定了,对你CPU的要求;
你的CPU满足游戏了,即使是双核照样跑得流畅;
你的CPU不满足某个游戏,选再高端的卡,也是白费;
发表于 2009-12-14 21:19:20
需要每秒150到200帧...
其实这个也不难 。。
帧数都不会低:a184:
wan19880125 发表于 2009-12-14 19:57
哪里哦,是游戏的运行帧数,这个帧数不容易哦,不是刷新率
发表于 2009-12-14 21:20:11
游戏决定了,对你CPU的要求;
albert2kiss 发表于 2009-12-14 21:12
恩,是啊,估计以后四核跑游戏了,种种测评都认为双核不怎么能胜任流畅这个标准了
发表于 2009-12-14 21:39:33
还是看游戏的 需要而定。
没有游戏 一切卡都是no。
多核 多线程 依旧是趋势。目前增加核心数 比 提高主频而言相对来得容易。
随着软件 和 游戏的支持,包括操作系统。合理的配置还是需要的
发表于 2009-12-14 23:26:33
我的5870CF配的是I7 950,刚配的。我也不知道咋样、、
发表于 2009-12-15 09:04:06
其实  Q6600 ~Q9~I7 都能喂饱
