[2009-5-6]UFO Download English 软件更新列表[UFO]
Software Name:PLCEdit 2.0.3( Installation of multi-language version)
Language:English
Software Size:3640KB
Introduction:
PLCEdit is a freeware source code editor for PLC programming.
PLCEdit can read, edit and create POU files, comptaible to Moeller SucoSoft and XSoft, all CoDeSys export files and Siemens IL and SCL sources.
With PLCEdit it is possible to create the different types of files, Program, Functionblock and Function.
The programming languages are Instruction List (in German AWL) and Structured Text.
Features:
support for Moeller, 3S Software (CoDeSys) and Siemens sources
programming languages Instruction List and Structured Text
sessions as different POE files in a desktop file
drag & drop opening and printing
a bi-lingual interface and help (en, de)
POU Info dialog for all files
enhanced CoDeSys support
redesigned print function
rebuild language handling
Down LCEdit 2.0.3( Installation of multi-language version) Software Name:Jailer 2.97(English green version)
Language:English
Software Size:4983KB
Introduction:
A powerful Java-based data export and extraction tool.
Jailer is a powerful and smart data extraction tool that enables you to:
· extract small consistent (referentially intact) row-sets from your productive · database and import the data into your development and test environment.
· remove and archive obsolete data from your productive database.
Extracts consistent, referentially intact row-sets from your R-DB (DB2, Firebird, Derby etc.).
Also Removes and archives obsolete data w/o violating integrity. Highly configurable, generates topologically sorted SQL-DML.
Down:Jailer 2.97(English green version) Software Name:WinPDF v1.0(English version is installed)
Language:English
Software Size:708KB
Introduction:
WinPDF offers an easy way of creating high-quality PDF documents out of almost any windows application. The software installs a PDF writer named "Easy PDF Creator" as if it were a real printer, making the creation of PDF files as easy as printing. Common documents can be converted to PDF files at an incredibly fast speed while retaining the look and feel of the original documents as well as many options that give users flexibility in PDF creation.
Down:WinPDF v1.0(English version is installed) Software Name:VMware Workstation 6.5.2 Build 156735 Windows(English version is installed)
Language:English
Software Size:468822KB
Introduction:
Discover the true power and flexibility of your desktop or laptop computer with VMware Workstation. Reduce hardware costs by 50% or more by running multiple operating systems simultaneously on a single PC. Automate and streamline tasks to save time and improve productivity. Join the millions worldwide who use Workstation to:
Host legacy applications and overcome platform migration issues
Configure & test new software or patches in an isolated environment
Automate tasks for software development and testing
Demonstrate multi-tier configurations on a single PC
Use Multiple Operating Systems Concurrently on the Same PC
VMware Workstation 6 makes it simple to create and run multiple virtual machines on your desktop or laptop computer. You can convert an existing physical PC into a VMware virtual machine, or create a new virtual machine from scratch. Each virtual machine represents a complete PC, including the processor, memory, network connections and peripheral ports.
VMware Workstation lets you use your virtual machines to run Windows, Linux and a host of other operating systems side-by-side on the same computer. You can switch between operating systems instantly with a click of a mouse, share files between virtual machines with drag-and-drop functionality and access all the peripheral devices you rely on.
Take Snapshots & Videos of your Virtual Machines
With Workstation, you can take a “snapshot” that preserves the state of a virtual machine so you can return to it at any time. Snapshots are useful when you need to revert your virtual machine to a prior, stable system state. Workstation displays thumbnails of all your snapshots on a single screen, making it easy for you to track and revert to a previously saved snapshot.
You can even use Workstation 6 to record and play video files that capture all changes to a virtual machine over a period of time. This function is exclusive to VMware Workstation and is incredibly useful for software debugging, Help Desk forensics, sales demonstrations and training.
Run an Entire Multi-tier System on a Single Host Computer
Run multi-tier enterprise applications on a single piece of hardware by managing network-connected virtual machines with the Teams feature of Workstation 6. Teams let you create virtual network environments that include client, server and database virtual machines.
With Workstation Teams, you can turn an entire multi-tier environment on and off with a single click of the mouse button. Workstation displays live thumbnails of all connected virtual machines, enabling you to easily identify and switch between the virtual machines associated with a team.
Clone your Virtual Machines to Accelerate Deployment
Installing operating systems and applications can be time consuming. With clones, you can make many copies of a virtual machine from a single installation and configuration process. This capability makes it fast and simple to distribute standardized computing environments to employees and students, or to create a baseline configuration for testing.
Take Your Virtual Machines With You
New to Workstation 6 is the ability to create and deploy secure virtual machines (called ACEs) with the ACE Option Pack. Mobility is one of the primary benefits of this option pack, as it enables users to securely take their desktops with them on portable media devices such as USB thumb drives.
KEY:63XPE-AUD07-M0NDY-4YEZL
Down:VMware Workstation 6.5.2 Build 156735 Windows(English version is installed) Software Name:The Dude 3.4 Final(Multi-language version of the green)
Language:Multi-language
Software Size:3564KB
Introduction:
The Dude is a unique network monitor that incorporates an interactive map of your network layout, that helps you visualize the structure of your network and provides direct access to network functions specific to each item. It can automatically discover your local network and draw a preliminary layout that can be further customized and saved. You can manually add items, customize the icons and captions used for each device and connect nodes with lines and other drawing tools. The program supports various network monitoring tasks from simple ping checks to port probes and service checks. Other features include history logging, outage notifications (email, beep, popup, eventlog), SNMP support, map export to PDF or PNG as well as customizable interface layouts and more.
Down:The Dude 3.4 Final(Multi-language version of the green) Software Name:Allway Sync 9.2.15(Multi-language version of the green)
Software Size:4136KB
Introduction:
When you work, even just occasionally, on multiple computers, you usually want your files to be where you are. Although you could always remember to copy all the modified files manually, there is a better way to apply your skills. Let Allway Sync keep track of recent changes in your files. This utility searches for the latest versions of your files in the specified folders, and copies the modified file to the counterpart folder, i.e. it synchronizes your folders. Unlike other directory synchronization software that just copies file with the most recent file modification time, Allway Sync implements a sophisticated algorithm which does not depend on system clock accuracy, and also propagates file and folder deletions properly. If your computers are not connected by a network, use a removable drive to synchronize them. Virtually any type of removable drive is supported: flash keys, card readers, USB drives, MP3 players, digital cameras, CDRWs, SAMBA, removable hard drives and many others. Allway Sync is fast, safe, stable and easy-to-use. All you need to do is to specify the local or network folders (directories) to be synchronized and the program does the rest. Advanced features include automatic synchronization, file filters, one-way and n-way sync option, usage statistics report, multiple jobs and more.
Down:Allway Sync 9.2.15(Multi-language version of the green) Software Name:Process Lasso V3.59.6(Multi-language version of the green)
Software Size:827KB
Introduction:
Process Lasso improves system performance, responsiveness, and stability in high load situations. It watches for processes consuming too much of the CPU and automatically restrains them to improve system responsiveness. It can also automatically terminate undesired processes, apply default priorities and CPU affinities to processes, or log all processes executed. It is not a task manager replacement, but does have task manager like capabilities only as a compliment to its core functions.
Down rocess Lasso V3.59.6(Multi-language version of the green) Software Name:XYplorer V7.90.0250(English green version)
Language:English
Software Size:1301KB
Introduction:
XYplorer is a multi-tabbed file manager for Windows, featuring a very powerful file search, versatile preview facilities, a highly customizable interface, and a large array of unique ways to efficiently automate frequently recurring tasks. Its innovative and its fun!
<FONT size=2>key:gree Y-677688</FONT>
Down:XYplorer V7.90.0250(English green version) Software Name:Eufony Lite v1.52(Multi-language version of the green)
Software Size:2041KB
Introduction:
Eufony Lite is a simplified free version of Eufony with features of managing/ playing audio files except for the encoding function. The Lite version supports MP1, MP2, MP3, WAV (PCM, IMA ADPCM, ALAW, and ULAW), CDA, OGG, AAC, eAAC+, AAC+, TTA, FLAC, APE, MPC, VOC, G721, G726, VYF, M4A, WMA, AMR and AWB. Its easy to use and fast!
Down:Eufony Lite v1.52(Multi-language version of the green) Software Name:TweakNow WinSecret 2009 V1.0(English version is installed)
Language:English
Software Size:4005KB
Introduction:
As a long time Windows user you might have heard about registry. The registry is a special file in your hard disk that hold most of Windows settings data. Wish to improve your internet speed or display message at Windows logon? No problem, those tasks can easily be done by simply editing the registry value. Unfortunately registry is not a friendly place for most people. Changing a wrong value in the registry may cause an unpredictable problem to your Windows. This is why novice users should not edit registry value directly using a registry editor by them self.
In TweakNow WinSecret, we have gathered the most popular Windows XP/Vista registry settings and provide them for you in an easy and safe user interface. All settings are divided in the following sections:
* Applications
* Control Panel
* Desktop
* Miscellaneous
* Network & Internet
* OEM Info
* User Accounts
* Windows Core
Down:TweakNow WinSecret 2009 V1.0(English version is installed) Software Name:Seven Transformation Pack V1.0(English version is installed)
Language:English
Software Size:21089KB
Introduction:
After windows 7 beta has been released windows vista interface looks too boring and bulky, In my opinion in I would say windows 7 is an upgraded version of windows vista with less bug, better look and feel and user acceptability.
Today we will tell you about another free transformation pack to transform vista to windows 7, it will change boring look of vista to windows 7 fresh new look.
Seven Remix is a completely free transformation pack which lets you enjoy the look and feel of windows 7 very easily. Seven Remix transformation pack is designed by niwradsoft
Down:Seven Transformation Pack V1.0(English version is installed) Software Name:Vista Transformation Pack V9.01(English version is installed)
Language:English
Software Size:27332KB
Introduction:
Bring to your desktop the look of Microsofts future operating system, Windows Vista
Im pretty sure you must know and have seen Windows Vista before. It looks really nice for major GUI updates. Many people who have seen it wish to get Vista-style looks for their operating system. It might sounds stupid to say this since you all know what it is but just bear it
Vista Transformation Pack will transform your Windows user interface to ultimate Windows Vista alike looks that everyone will never notice its the same old Windows XP (or 2003).
Vista Transformation Pack gives to your Windows XP system the fresh and cool look of Microsofts new operating system: Windows Vista. The pack changes most of the system icons, skins and toolbars and also adds new enhancements to your desktop such as
You sure will be surprised if you hear this. From now on you can update Vista Transformation Pack without uninstalling and you can even integrate Vista Transformation Pack into Windows setup files.
Down:Vista Transformation Pack V9.01(English version is installed) Software Name:XdN Tweaker V0.9.1.6(English green version)
Language:English
Software Size:207KB
Introduction:
Features:
* Changes the number of Folder views Windows saves.
* Resets the folder views Windows has saved.
* Add/Remove classic Windows 2000 user control panel icon.
* Disable/Enable ATI Catalyst Control Center right click on Desktop
(only for use if you have an ATI video card and have the Catalyst Control Center installed).
* Disable/Enable ‘SendTo’ right-click menu.
* Allows you to adjust and tweak TCP/IP settings.
* Disable/Enable ZipFolders.
* Disable/Enable the Outlook Express/Windows Mail splash screen.
* Put the File menu above the Back/Forward buttons in IE7.
* Remove or Replace the Search box in IE7.
* Disable/Enable User Account Control prompts under Vista.
* Disable/Enable the “- Shortcut” text under Vista.
* Attempt to force Vista to better save folder views.
* Disable/Enable Windows Media Player Explorer context menus.
* Add/Remove “Take Ownership” to right-click menus under Vista.
* Disable/Enable the Documents item on the Classic Start Menu.
* Changes “Delete” to “Search…” on Recycle Bin.
* Turn off the annoying full screen “black” UAC prompt.
Down:XdN Tweaker V0.9.1.6(English green version) Software Name:Popcorn 1.90(English green version)
Language:English
Software Size:241KB
Introduction:
Popcorn is an ultra-lightweight POP3/SMTP e-mail client, that allows you to read mail from a POP3 server directly, without downloading it to a local mailbox on your PC (although you can save mail messages to disk if you want to). This makes it ideal for "on the road" email access, and for scanning, reading and sending mail over slow internet connections. Popcorn supports multiple user profiles and fits on a floppy disk. The user profiles and account information is NOT saved in the local registry, but in a small, portable .INI-file that accompanies the application, enabling you to easily move between locations. Using Popcorn you can check and send mail from anywhere as long as you have an Internet connection. You can also delete spam, old messages or see if a message has attachments without downloading the messages from the server first. It is perfect for cleaning up and administering multiple POP3 accounts.
Down opcorn 1.90(English green version) Software Name:CheckDisk 1.05(English green version)
Language:English
Software Size:184KB
Introduction:
CheckDisk is a powerful tool for searching and repairing disk errors. It is quite similar to the ScanDisk tool or chkdsk.exe, supplied with the Windows operating systems.
You can select either standard or full tests. The full test additionally performs a sector check. It is capable of finding bad sectors on your disk and marking them as such. CheckDisk will work with HDDs (including SCSI and RAID), removable media and CDs.
Down:CheckDisk 1.05(English green version) |
