AMD真的很出息,开核开到显卡上了:部分5830采用5850核心
发表于 2010-3-5 22:11:12
Some HD 5830s said to be coming with HD 5850 cores - BIOS hacks anyone?
DiggThis         Share                 Share
Print | Email | Font Size: A A
Author: Steve Dougherty       Posted: 7 hours, 43 mins Ago
Our VGA guru Shane Baxtor has posted some hot news over at his Blog page pertaining to the new HD 5830 which is already a hot little number in AMD's HD 5000 series lineup with solid performance at a good price.
He learns that we might be seeing a bit of de ja vu, reminiscing of the X800 days where it was possible to unlock more stream processors by simply flashing the card with a different BIOS.
Whilst not confirmed nor said to be happening with every HD 5830 to hit the market, Shane hears that companies are looking to place the HD 5850 core on select HD 5830 cards which would then make it as simple as using a BIOS hack to unlock the extra stream processors the HD 5850 has on tap. Followed by a core and memory overclock from there and you're looking at sensational performance that makes the already attractive value factor of the stock HD 5830 glow even more.
But as mentioned above, this information hasn't yet been confirmed and until one is seen in the flesh with the GPU cooler removed to confirm what core has been used, we won't know for sure.
Fingers crossed!
发表于 2010-3-5 22:11:43
翻译部分:有些高画质的5830s说是未来的HD 5850核心 - 改造BIOS的人?
DiggThis分享分享
打印|电子邮件|字体大小:A甲
作者:史蒂夫多尔蒂发布:7小时43分钟前
我们的显卡大师巴蒂尔Baxtor已发布了一些热点新闻在他的博客页关于新的HD 5830已是一个热点在AMD的HD 5000小数目在一个良好的价格强劲表现推出系列产品。
他得知我们可能会看到一个似曾相识的统计ja位的X800天的地方,有可能通过简单地回忆解锁闪动不同BIOS的卡多流处理器。
虽然没有证实,也说是每高清5830 发生在进入市场,巴蒂尔听说公司正在寻求放置在选择高清5830卡,然后将房屋署5850的核心是使用简单的BIOS黑客解锁的额外流处理器,房屋署已在5850水龙头。其次是核心,并从那里内存超频和你在耸人听闻的表现,使得股票的高清5830焕发更加具有吸引力的价值因素已经寻找。
但正如上文所述,此信息尚未得到证实,直到一个是在与删除,以证实了核心使用了GPU的凉肉看到,我们不会知道。
发表于 2010-3-5 22:15:21
国内行货市场 不会有5830
发表于 2010-3-5 22:17:08
这种消息已经屡见不鲜了
从U显卡
AMD一直在努力
发表于 2010-3-6 07:25:49
还没有证实嘛.不过出现这个情况也是正常,4830不也能开SP到4850吗?
发表于 2010-3-6 14:16:35
是啊  也不能妄加评论
发表于 2010-3-6 22:40:12
能开SP的5830价格不会比5850低多少……
发表于 2010-3-7 21:51:16
不能妄加评论
