我的电脑一开机就蓝屏,蓝屏代码是(如下): 求高手解答!的电脑一开机就蓝屏了,蓝屏代码是(如下):
A problem has been detected and windows has been shut down to prevent damage to your computer If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these steps:Check to be sure you have adequate disk space, If a drlver ls
ldentified in the Stop message, disable the driver or check
with the manufacturer for driver updates. Try changing video
adapters.Check with your hardware vendor for any BIOS updates.Disable
BIOS memory options such as caching or shadowing. If you need
to use Safe Mode to remove or disable components, restart your
computer, press F8 to select advanced Startup Options, and then
select Safe Mode.Technical information:*** STOP:0x0000007E (0xc0000005,0xf3cf177a,0xf78D29A8,0xf78D26A4)*** RtkHDAud.sys - Address F3CF177A base at F3A66000, DateStamp 4a8a750b
