Evercool 发布新款扁平式CPU散热器
发表于 2010-11-30 01:51:57
Evercool发布了一款扁平式cpu散热器——HPL815-EP。大小为106*95*45mm,重约320G,支持LGA1366\1156\775和AM系列散热器,甚至能适用于i7 980X和1090T这样的高TDP的CPU。其具备4根8mm热管可以直接接触CPU表面,风扇尺寸92mm,转速1000-4000RPM,价格仍未公布,不过显然是HTPC或者小型机箱的绝配~哈哈
Evercool Develops New Performance Low-Profile CPU Cooler
Evercool added a new low-profile CPU cooler to its lineup, the HPL815-EP. Although a little diminutive, measuring 106 x 95 x 45 mm, weighing 320 g, the cooler supports all popular sockets, including LGA1366, LGA1156, LGA775, AM3/AM2+/AM2, including six-core Intel Core i7 980X, and AMD Phenom II X6 1090T. The design a CPU base in which four 8 mm thick copper heat pipes make direct contact with the CPU, conveying heat to a dense aluminum fin array that propagates along the plane of the motherboard, instead of perpendicular to it (like a common tower-type cooler). A 92 mm fan latches onto the heatsink using metal clips. The fan spins at 1,000~4,000 RPM. Evercool did not let out pricing details.
