Renowned overclocker Duck set a new record 3DMark Vantage. The record was set at an event apparently conducted by Galaxy Tech. The record now stands at P75324 points. Duck used four Galaxy GeForce GTX 580 graphics cards in 4-way SLI to achieve the feat. It appears as if at least one, if not all, use an ASUS BIOS, perhaps to avail the VoltageTweak feature. Apart from the graphics cards, Duck's bench consisted of two Intel Xeon E5680 Westmere-EP 6-core/12-thread processors clocked at 5368 MHz, EVGA Classified SR-2 dual-LGA1366 motherboard, 6x 2 GB Corsair DDR3-2000 MHz CL7 memory, multiple 1200W PSUs (Corsair AX1200W + SilverStone Strider Gold SST-ST1200G), and Intel X25-M 80 GB SSD. In the cooling department, there are Duck's own JCA Water Bear Pot WB02A and K|ngp|n F1 cooling the two processors, K|ngp|n Tek9 4 and 5.0 cooling the GPUs, a custom heatsink cluster cooling the GPU VRM, and gobs of insulation.
3dmarkVANTAGE的新世界纪录,影驰创造,P75324分。4路580sli,使用了华硕BIOS,使用两个志强E5680的6核12线程处理器,超频到5368MHz,EVGA的双LGA1366槽主板,6*2G的DDR3 2000 CL7内存,海盗船1200W和银欣1200W双电源,INTEL X25-M的80G SSD,当然还有极限超频的显卡。。。
