Scythe Co. Ltd. extends the popular Gentle Typhoon fan series by three powerful high RPM models. The new Gentle Typhoon High RPM fans are available with 3.000, 4.250 and 5.400 rpm. These high fan speeds generate an incredible airflow of 141, 197 and 255 m³ per hour (83.0 / 116.5 / 150.1 CFM).
In direct comparison to fans with similar specs, the Gentle Typhoon High RPM series scores with a significant lower noise. Like the normal GT models, a perfectly balanced Nidec Servo bearing is used, ensuring an average MTBF of 100.000 hours. The reliable motor operates with an almost fluctuation-free rotational torque. Vibrations transferred from the motor to the venturi (fan case) are reduced to a minimum.
