Serv-U 10.5.0.4
发表于 2011-3-16 23:59:21
Serv-U 是目前众多的FTP 服务器软件之一.通过使用Serv-U,用户能够将任何一台PC 设置成一个FTP 服务器, 这样,用户或其他使用者就能够使用FTP 协议,通过在同一网络上的任何一台PC与FTP 服务器连接,进行文件或目录的复制,移动,创建,和删除等.这里提到的FTP 协议是专门被用来规定计算机之间进行文件传输的标准和规则,正是因为有了象FTP 这样的专门协议,才使得人们能够通过不同类型的计算机,使用不同类型的操作系统,对不同类型的文件进行相互传递.
Serv-U Version 10.5.0.4
Serv-U 10.5.0.4 was released March 14, 2011. A complete list of changes and upgrades follows:
Features:
  • Added system variable "$CurrentDirMaxSize".
  • Added logging of execute event "Command Line Parameters" in addition to the "Executable Path".
  • Changed the implementation of the FTP command "ABOR" to more closely follow RFC 959 when a command is in-process. When an FTP Command is in-process RFC 959 calls for the 4xx response first, then the 226 response for the ABOR command.
  • Added the "X-Frame-Options: sameorigin" HTTP header value to prevent clickjacking within most modern up-to-date browsers.
  • Allow secure listeners to be disabled in Serv-U Bronze and Silver.
  • Added the ability to enable/disable listeners from the context menu in the Management Console.
  • Changed the installer to recognize Windows 7 and greater so that the "Create a Quick Launch icon" no longer appears as an option.
  • Added icons to the Tray's About box categories.
  • Changed the way dialogs are centered on the screen. Dialogs are now centered in relation to working area instead of the window size.
  • Updated context menu icons in the Management Console.
  • Changed the Page Up/Down keyboard events to scroll the size of the viewable list area. Previously, this was set to a static value of 10 rows per event.
  • Added new bookmark icons to the Mobile Web Client for iPhone, iTouch, and iPad.
  • Added the icons that correspond to the frames for the "Activate Frame" dialog in FTP Voyager JV.
  • Changed FTP Voyager JV when "localhost" fails to connect to Serv-U, FTP Voyager JV will retry IPv6 "[::1]" and then IPv4 "127.0.0.1" loopback addresses before the connection error dialog is displayed.
  • Added icons to the About box categories for FTP Voyager JV.
  • Changed the FTP Voyager JV "Options" dialog to use less real estate.
  • Improved FTP Voyager JV and Web Client natural sorting to sort symbols before alpha numeric characters.
  • Enlarged RhinoSoft and reseller logos for the About dialog in FTP Voyager JV.
  • Improved FTP Voyager JV About and Preferences dialogs to accommodate translations better across all supported Operating Systems.
Bug Fixes:
  • Corrected a bug, introduced in 10.4.0.0, where the setting to disallow HTTP IP address changes caused Serv-U to disallow all IP address changes, even when specifically allowed by this setting.
  • Corrected a bug where the backslash character was not being validated as an invalid character for SSL certificates and SSH key pairs. When backslash was used as part of the name a generic error would be displayed.
  • Corrected a bug where execute events were being logged twice.
  • Corrected a bug where HTTP/HTTPS, SFTP (via SSH2), and sometimes FTP/FTPS upload and download failures were not being logged and the "File Download Failure" event was not being triggered.
  • Corrected a potential handle leak in the Serv-U tray application. Over time, the Serv-U Tray could consume a large number of system handles.
  • Corrected a bug in the Management Console where combo boxes with icons did not render correctly in Opera.
  • Corrected a bug in the Management Console where the drop down list for database mapping was cut off at the top when using Safari or Google Chrome browsers.
  • Corrected a bug in the Management Console where the member list in database groups was being truncated when using the Internet Explorer browser.
  • Corrected a bug in the Management Console where password recovery for database users was not working correctly.
  • Corrected a bug in the Management Console where text boxes in the events dialog would not scroll back to top position after closing the dialog.
  • Corrected a bug in the Management Console where FTP response codes where not being sorted correctly on the initial dialog loading.
  • Corrected a bug in the Management Console where the database mapping dialog did not reset values properly when being loaded.
  • Corrected a bug in the Management Console and Web Client where right click context menus did not work correctly on Linux operating systems.
  • Corrected a bug in the Management Console where the date for disabled or auto-delete users was not correctly lined up with the login ID when using Chrome, Safari, Firefox, or Opera.
  • Corrected a bug in the Mobile Web Client where the "Go" button did not submit the login correctly.
  • Corrected a bug in the Mobile Web Client where the directory information icons where not right justified on the Apple iPad.
  • Corrected a bug in the Web Client where file search results were not being sorted based on selected column or direction.
  • Corrected a bug in the Web Client where sorting on file size and date were not working.
  • Corrected a bug in the Web Client where the history navigation was not using the correct paths when clicking the next and back history navigation buttons.
  • Corrected a bug in the Web Client where the original rename path was being converted to a lower case string when renaming a file or directory.
  • Corrected a bug in FTP Voyager JV where a right-click would not move focus to the correct browser pane.
  • Corrected a bug in FTP Voyager JV where a drag & drop operation could relist the current working directory causing sorting errors.
  • Corrected a bug in FTP Voyager JV where the selection that shows the current view was not being reset for the main menu and ** buttons.
  • Corrected a bug in FTP Voyager JV where the Search options would not be position correctly on dual-monitor setups.
  • Corrected a bug in FTP Voyager JV where the Search options would remain visible if the drop-down button was pressed again.
  • Corrected a bug in FTP Voyager JV where the "Activate Frame" dialog could not be dismissed when pressing the "ESC" key.
  • Corrected a bug in FTP Voyager JV where the thumbnail image would randomly fail to fill the entire length or width of the Preview pane.
  • Corrected a bug in FTP Voyager JV where the thumbnail image would be regenerated when it was not necessary.
  • Corrected a bug in FTP Voyager JV where the file icon would not refresh if a rename operation changed the file's extension.
  • Corrected a bug in FTP Voyager JV where the thumbnail for an "Overwrite" confirmation could be incorrectly filled in if a "Preview" thumbnail was initiated at the same time.
  • Corrected a bug in FTP Voyager JV where the reseller icon's link in the About dialog was not properly formatted.
  • Corrected a bug in FTP Voyager JV on Mac OS where the logout confirmation dialog was not sized correctly.
  • Corrected a bug in FTP Voyager JV where the crumb button drop-down would cause the file panel to update its listing.
  • Corrected a bug in FTP Voyager JV where a formatting problem for foreign languages would fail to render transfer items in the transfer queue.
  • Corrected a bug in FTP Voyager JV where a "Synchronize Folders" dialog would not close if the "ESC" key was pressed.
  • Corrected a bug in FTP Voyager JV where a "Save Login" dialog would not close if the "ESC" key was pressed.
  • Corrected a bug in FTP Voyager JV where the dialogs were not large enough to contain string translations.
  • Corrected a bug in FTP Voyager JV where the "Overwrite Confirmation" dialog was not rendering translations correctly for Japanese and Chinese characters.
  • Corrected a bug in FTP Voyager JV where the local and remote listings would both update if the directory path is the same between both file systems.
  • Corrected a bug in FTP Voyager JV where a listing would not occur when the tree node was expanded by pressing the (+) graphic.
  • Corrected a bug in FTP Voyager JV where a failed upload operation wouldn't produce an immediate error dialog due to the auto-resume feature.
