解读世界最昂贵的集成电路功放 47Labs功放4706探秘
版主
Rank: 7Rank: 7Rank: 7
发表于 2013-4-5 13:07:27
本文试图将已有的相关资料总结在一起,以待有缘人进一步开拓。先看一下厂家的公开信息。
  Features:
  World's smallest number of parts - 9 parts per channel ( excluding attenuators );
  World's shortest signal pass length - 32 m/m ( including the length of parts );
  World's shortest NFB loop length - 9 m/m ( including the length of the resistor );
  World's smallest filter/condenser - 1000μF, (50W version - 2200μF);
  Powerful voltage regulation with high capacity transformer - 170 VA cut-core transformer  +-individual coils;
  Dual mono construction with each channel in a separate chassis;
  Rigid and compact aluminum chassis construction to release vibrations smoothly;
  Separate 12-position attenuators for each channel;
  Can be up-graded into a pair of complete mono amplifiers by adding another Model 4700 Power Humpty。
  Specifications:
  Output power: 25W+25W ( 8) (50W version : 50W+50W)
  Input impedance: 22k ( unbalanced only )
  Attenuators: 12-steps for each channel
  Output on and off switches for each channel
  Dimensions:
  Model 4706 170(w)x40(h)x100(d)m/m
  Model 4700 130(dia.) x195(d) m/m
  厂家网站公布的价格
  price on the right indicates the new price starting Oct.1/2011
  Shigaraki Series
  Model 4716                 CD Transport                 $2,550
  Model 4715                 DAC                                  $2,000
  Model 4717                 Integrated Amplifier        $2,550
  Model 4718                 Phono                         $2,250
  Reference Series
  Model 4706                 Gaincard                 Amplifier Unit                 $1,850
  Model 4713                 Flatfish                 CD transport unit        $4,400
  Model 4705                 Progression        DA Converter unit         $3,400
  Model 4705-G                 Progression/Gemini                 DA Converter unit                 $4,500
  Model 4712                 Phonocube                 Phono Equalizer Unit                 $2,750
  Model 4704                 PiTracer                 CD transport Unit (with one Power Humpty)                 $32,500
  Model 4700                 Power Humpty                 Power supply (50W version $2,800)                 $2,250
  Model 4799                 Power Dumpty                 Power Supply                 $2,250
  Model 4707                 Input Chooser                 Selector Box                 $1,000
  Model 4724                 Koma                 Turntable                 $12,000
  Model 4725                 Tsurube                 Tonearm                 $2,250
  Model 4708                 OTA Cable Kit                                  $800
  Model 4719                 Speaker Cable                                  $800/8ft pair
  $1,000/10ft pair
  Model 4722                 Lens Speaker System                 $2,500/pair
  Model 4723                 MC Bee                                  $1,500
  Konus Audio "Essence"                  Speaker system                 $5,000/pair
  采用LM1875设计的4706是放大单元,要和电源单元4700配合,$1850+$2250=$4100,是美刀,不是人民刀。这个功放是不是HiFi——进了美国发烧天书,B级器材榜单。下面先上一些国外玩家的拆解图片。
  这其中有线路图还有拆机图片。不一一细分了。再上一个泰国老烧的DIY旅程,因为是泰国语网站,用图片说话吧,比较有代表性。整个DIY过程分为几大步,这也为我们的探索指明了方向。
  第一步:线路板复刻,电位器复刻,装机,测试
  第二部:独立机壳,这里实际上是做了两个步奏,换独立机壳,换电容。
  第三部:机壳复刻
  第四步:换变压器
  此文的代表性在于作者有两台真机,拆一台听一台。而且与我想象不同的是,这个作者居然用4706推的是大喇叭,照片超大,上不去,又不会减像素,感兴趣的烧友到网站去看看吧。前两部应该是不太满意,才有的第三部。实在是不懂泰国语,也不知道最后的结果怎么样。
  关于设计师的设计理念,他在Audio Amigo杂志1995年第二期上曾发表了一篇文章《Op-amps are More Fun than Tubes》,他在里面提出了一个非常特别的观点,就是工作于低阻状态下的运放(这里更象是说集成功放,因为集成功放从本质上来说就是可输出大电流的运放),其负反馈环路每增加1CM,相当于高阻状态下的胆线路的10CM长甚至更长,加上运放应用中的负反馈量太大,容易是产生了高达100M、200M的振荡或趋向于振荡,而且难以观察得到,因此他通过尽可能缩短负反馈环路来消除振荡。此文中,他说自己的GAINCARD得到了胆迷的喜爱——DIYAUDIO论坛上加拿大网友PETER DANIEL的一个帖子也说,他几个朋友听了他装的两台机子GAINCLONE、PASS的Aleph后,喜爱胆声的朋友很喜欢GAINCLONE,其余的喜欢Aleph.
  仿制:
  1、在装制中,都注意将反馈电阻十分贴近IC来安装,以贯彻原型机的设计理念。小弟前两天装的LM3875的GAINCLONE就是把电阻直接焊在IC引脚的根部上,呵呵。
  2、用的IC都有多种,既有原装用的LM3875,也有LM3886、TDA的、OPA的。我看到的帖子没有留意到有LM3886与LM3875的比较,反倒看到少数帖子提及TDA7294、OPA549(称TDA7294差于LM3875、OPA549则好一点)。但其中最多人还是用LM3875。
  3、既有玩同相放大,也有玩反相放大。大家都说好,似乎谁也说服不了谁(原装的是同相放大)。有的人说同相放大的线路声音细节多一些,有的人虽试过连装几台都是反相放大的。甚至有的人在音量电位器前加装胆缓冲或运放缓冲。
  4、电源滤波电容容量问题。视自己的喜欢而定,有1000U的,也有用10000U的。
  5、有改为直流放大线路的(即取消隔直电容),有仍使用原装的交流放大结构的。
  6、其它有关老外装制中的信息:一是有的装成合并式,有的装成纯后级式然后配前置,不过按原装的合并式的为多。二是电源变压器每声道多数配150W以上(或两声道300W),使用分离双绕组的占多数,一般取交流双22V。三是多使用高速整流二极管(大多推荐摩托罗拉的MUR860)构成双桥式电源——因此需变压器有分离双绕组。四是滤波电解大多选用高品质的,比如BLACK GATE、乐声的FK、ENLA的SILMIC等。五是耦合电容有使用薄膜电容,也有用高品质电解的(原装机的小电解是用NICHICON的MUSE)。六是接线多选用单支硬线。七是有不少人是搭棚制作的。 遗憾的是,我一直未找到原装机GAINCARD线路,只知道原装主机内的9个元件和线路的大概。这是一个DIYAUDIO论坛上网友发表的一个同相直流放大GAINCLONE线路( 摘自小鬼头)
  先来整理下思绪提几个问题,
  1、它的用料好在哪?
  2、它的接线好在哪?
  3、它的机箱好在哪?
  好了问题出来了来看看如何去解答,首先用料,整机看起来除了电位器比较重料以外好像没有太重料的地方,其次接线,老烧们都比较重视整机的接线,机内线一定要重料,要理好线,走线要清晰,而在这个机子里我们没有看到重料的线材,也没有看到清晰的走线,甚至可以说它的机内线很寒酸,走线很凌乱,最后机箱,它没有傲人的散热,只是将两个声道单独开来而已,以上应该说是我看到它的第一印象,但是所有听过它的都说他的声音非常好,甚至可以说是惊艳的,那怎么做到的呢,他已经将我们所有已知的经验都推翻了,是这样吗?回答是否定的。
  首先从走线看,这台机器已经将走线做到了极致,我们知道无论什么电器它的接线越短那么空气中以及线材间的高频干扰渗透进去的可能性就越小,这台机器中如果按一般的走线的话PCB会更大,而我们看到的是很小的PCB加上难看的搭棚,而这一切都是为了尽可能的缩短接线长度,甚至从电位器到PCB的接线都是直接用电阻和电容的接脚代替了机内线,再看它的信号线,没有用我们所熟识的屏蔽线更没有银线只是看上去很普通的机内线,为什么会这样呢,原因应该在它的机箱上,它的机箱首先是单声道全密封的,其次机箱深度目测不超过10CM,这两项加起来是的它的信号输入线根本不必要使用屏蔽线,因为会干扰到输入信号的干扰都被屏蔽在了机箱外,如果你说不是还有电源线等等的接线空吗,对是有孔,但是首先电源线流进机箱的是经过整流的20几伏直流电,再有所有的开孔在穿好线材后基本上剩余的孔径没有超过7MM的,再有它的电源线可以看到是4线的,增加了一根黑色的地线,这根电源线应该也是有屏蔽的。
  再来看看它的机箱,按照他的PCB尺寸它的机箱完全可以做的再小些,这个应该是为了照顾到它的散热,另外一方面想它也可以做的更大些,为什么它没有这么做呢,首先做的更大些,倒是好看了,但就违反了上面说的,增加了出现干扰的可能性,还有一个问题就是每个零件都有他的最佳工作状态,在以往的文章中大家都很重视它的电压高低,电流大小,希望它能工作在最佳的电压,电流下,但是还有一个参数大家好像很少提及那就是零件的工作温度,每一个零件不但有最佳的工作电压,电流还有一个最佳的工作温度,温度高了低了都会影响它的工作表现,我们自己DIY是基本上都是给功率原件很大的散热,生怕它温度高了会烧掉,原则上这是对的,但也恰恰是这个原则扼杀了原件的个性,而这台机器并没有太夸张的散热,应该是设计者有意为之,使其发挥出它应有的零件个性,而连接两个单独的箱体的前后面板有恰如其分的成为了两片3875的均热板,使得它有更好的热耦合性。
  还有就是每个声道都是单独控制音量,和开关的的,这样就省去了喇叭保护装置,使得干扰出现的可能性进一步降低,提高每个声道的信噪。上面所有的集合在一起就行吗?不还没完,还有电源,如果能每声道一个就完美了,而事实上他们就是这么干的。
