[求助] autocad2006安装出错!
发表于 2007-4-4 14:33:00
intaller版本升级到3.0   把flash升级到最新!应该是9.0吧  然后再试试吧~
发表于 2007-4-4 16:59:00
安装文件不要放在中文目录下
发表于 2007-4-4 17:23:00
2006有什么好???一直2004。。。无视其他版本
发表于 2010-3-10 08:29:12
求助:我安装autoCAD2006出错。
错误:1325。“Favorites"不是有效的短文件名。
请教高手,指点一下。谢谢!!!
发表于 2010-3-10 08:32:19
显示为:
[3/10/2010 08:15:32] === Installation started on 张健 by Administrator ===
[3/10/2010 08:15:34] [Info] Windows Installer upgrade is not required
[3/10/2010 08:15:34]   System Version = 3.1.4001.5512
[3/10/2010 08:15:34] Installation skipped: MSI Runtime 3.0
[3/10/2010 08:15:34] [Info] .NET Framework Runtime upgrade is not required
[3/10/2010 08:15:34]   System Version = 2.0.50727.1433
[3/10/2010 08:15:34] Installation skipped: .NET Framework Runtime 1.1
[3/10/2010 08:15:34] Installation started: .NET Framework Runtime 1.1 Language Pack
[3/10/2010 08:15:34]   Command = "I:\AutoCAD2006简体中文版\Bin\AcadFEUI\support\dotnetfx\chs\langpack.exe" /q:a /c:"inst /qb"
[3/10/2010 08:15:36] Installation succeeded: .NET Framework Runtime 1.1 Language Pack
[3/10/2010 08:15:36] [Info] .NET Framework Runtime upgrade is not required
[3/10/2010 08:15:36]   System Version = 2.0.50727.1433
[3/10/2010 08:15:36] Installation skipped: .NET Framework Runtime 1.1 SP1
[3/10/2010 08:15:37] [Info] MDAC upgrade is not required
[3/10/2010 08:15:37]   System Version = 2.81.1132.0
[3/10/2010 08:15:37] Installation skipped: MDAC 2.7
[3/10/2010 08:15:37] Installation started: Autodesk DWF Viewer
[3/10/2010 08:15:37]   Command = "I:\AutoCAD2006简体中文版\Bin\AcadFEUI\support\aev\DWFViewerSetup.exe" /u2 /q2
[3/10/2010 08:15:38] [Error: 11] 试图加载格式不正确的程序。
[3/10/2010 08:15:38] Installation failed: Autodesk DWF Viewer
[3/10/2010 08:15:38] [Info] Failure is ignored
[3/10/2010 08:15:38] Installation started: Flash
[3/10/2010 08:15:38]   Command = "I:\AutoCAD2006简体中文版\Bin\AcadFEUI\support\flash\Silent Install Flash Player 7 AX.exe" /q
[3/10/2010 08:15:42] [Error: 1] 函数不正确。
[3/10/2010 08:15:42] Installation failed: Flash
[3/10/2010 08:15:42] [Info] Failure is ignored
[3/10/2010 08:15:42] Installation started: AutoCAD 2006
[3/10/2010 08:15:42]   Command = msiexec /i "I:\AutoCAD2006简体中文版\Bin\AcadFEUI\acad.msi" /L*v C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\AcadInstall.log
[3/10/2010 08:17:17] [Error: 1603] 安装时发生严重错误
[3/10/2010 08:17:17] Installation failed: AutoCAD 2006
[3/10/2010 08:17:17] Installation aborted
[3/10/2010 08:17:19] === Installation ended ===
12
返回列表 发新帖
