HIFI耳机新伴侣 TEAC HA-501耳放
版主
Rank: 7Rank: 7Rank: 7
发表于 2013-1-18 13:18:46
导读:TEAC HA-501不仅采用好音质保证的A类线路设计,内部以双单声道(Dual Mono)组成的平衡架构更是耳放产品中少见的设计,除了基本的RCA端子,更有发烧的XLR平衡端子。
还嫌自家耳放的声音不够Hi End吗?TEAC新推出的这款HA-501耳放应该可以让你大享耳福。
TEAC HA-501耳放
TEAC HA-501不仅采用好音质保证的A类线路设计,内部以双单声道(Dual Mono)组成的平衡架构更是耳放产品中少见的设计,不仅可减少内部零件的交互干扰,更可大幅增加音场再生与左右声道的分离度。并使用了Muses 8920的OP放大器。
TEAC HA-501耳放 - 正面
TEAC HA-501耳放 - 背面,后方端子,除了基本的RCA端子,更有发烧的XLR平衡端子。
TEAC HA-501耳放 - 内部
除此之外,HA-501共有五段可调式阻尼设计,包括at32、at64、at120、at300,以及at600欧姆。内部也以一颗大型的环形变压器给予最纯净的电源供应。整机采用高强度的全金属机箱,两侧侧板则是铝材。
TEAC HA-50耳放 - 环形变压器
DAMPING FACTOR调节旋钮
Audio Input
Balanced Input (Rear)
1 pair
Connectors
XLR-3-31 (1:GND, 2:HOT, 3:COLD)
Impedance
20k ohms
Sensitivity
2Vrms
Line Input (Rear)
2 pairs (LINE1, LINE2)
Connectors
RCA Pin Jack (Gold-plated)
Impedance
10k ohms
Sensitivity
1Vrms
Auxiliary Input (Front, AUX)
Connectors
1/8" (3.5mm) Stereo Mini Jack
Impedance
13k ohms
Sensitivity
0.5Vrms
Audio Output
Headphone Output (Front)
Connectors
1/4" (6.35mm) Stereo Jack
Supported Headphone Impedance
16 ohms - 600 ohms
Max Output Level
1,400mW + 1,400mW (at 32 ohms)
135mW + 135mW (at 600 ohms)
Rated Output Level
600mW + 600mW (at 32 ohms)
34mW + 34mW (at 600 ohms)
THD
0.002% (Input 1V, Output 1V, at 32 ohms)
0.01% (Input 1V, Output 600mW, at 32 ohms)
S/N Ratio
110dB (RCA Input, 2Vrms 1kHz, A-weighted)
Frequency Response
2Hz – 100kHz (+0dB/-3dB)
10Hz – 100kHz (+/-3dB)
Line Output (Rear)
Connectors
Impedance
100 ohms
Output Level
316mV
Output Level Selector
Fixed, Variable, Off
Operation Power
120V AC, 60Hz (US/Canada)
230V AC 50Hz (UK/Europe)
Power Consumption
22W (Standby: 0W)
Operating Temerature
+5C to +35C
+41F to +95F
Operating Humidity
5% to 85% (no condensation)
Storage Temerature
-20C to +55C
-4F to +131C
Overall Dimensions
290 (W) x 81.2 (H) x 244 (D) mm, 11.4" (W) x 3.2" (H) x 9.6" (D)
Net Weight
4.1kg, 9 lbs
Accessories
AC Cable, AC Plug Adapter (3P-2P), Owner's Manual, Warranty Card
