电脑故障速排方法(06年11月10日更新)
发表于 2006-11-10 21:22:00
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN =title1><B><SPAN style="FONT-SIZE: 14pt; COLOR: navy; FONT-FAMILY: 仿宋_GB2312">激光打印机故障</SPAN></B></SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; COLOR: navy; FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: Arial; mso-bidi-font-family: Arial"><?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt">常见故障一</SPAN><SPAN lang=EN-US style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: Arial; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">:</SPAN><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: Arial; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">联机打印时,进纸正常,但打印无字迹。</SPAN></FONT><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: Arial; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><BR></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: Arial; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>  <SPAN lang=EN-US>1</SPAN>、先更换新的粉盒看故障是否消失。更换时应先检查墨粉密封条是否拉出、墨粉是否已经用完。如若密封条没有拉出或墨粉已用完,就会造成字迹全无现象;但若是粉盒内墨粉用完的故障现象是输出样张先是纵向中间部分逐渐变淡,红色显示灯不停闪烁告警,提示机内粉盒中墨粉即将用完。打印字迹全无的现象非常罕见,且须在图像变淡后经过较长一段时间,故基本排除粉盒内无墨粉的原因。</FONT><SPAN lang=EN-US><BR></SPAN><FONT size=3>  <SPAN lang=EN-US>2</SPAN>、接着检查激光打印机硒鼓是否故障。仔细检查发现硒鼓表面上有文字的墨粉痕迹,故判定打印机显影部件无故障,问题出在字迹从硒鼓感光鼓向纸上转移阶段。</FONT><SPAN lang=EN-US><BR></SPAN><FONT size=3>  <SPAN lang=EN-US>3</SPAN>、最后检查转印电极组件上的电极丝,发现电极丝并未熔断脱落,但在电极丝的前后左右附着有大量的黑色漏粉,从而判定故障出自大量的带电漏粉致使电极丝无法发生正常的电晕放电,或发生电晕放电电压过低,无法将带负电的显影墨粉吸附到纸上,从而造成打印纸上无字迹现象。<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>解决办法是用一小团洁净棉花蘸取少量甲基乙基酮,在关机状态下轻轻擦拭,清除转印电极组件上电极丝周围的碳粉。清理完毕后,再用一小团棉花蘸取少量无水酒精重新擦拭一遍,等酒精挥发干净后,重新安装到位。开机使用,打印文字正常,故障随即排除。<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><o:p><FONT size=3>&nbsp;</FONT></o:p></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>常见故障二:</FONT></SPAN><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>打开打印机电源开关,打印机“嘎、嘎”响,并报警,系统提示无法联机打印。</FONT><SPAN lang=EN-US><BR></SPAN></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>  排除:这与使用环境和日常维护有很大关系。如果使用打印机的环境差、灰尘多,就比较容易出现这个问题。因为灰尘聚积在打印头移动的轴上,和润滑油混在一起,越积越多,形成较大的阻力,使打印头无法顺利移动,导致无法联机打印。可以关掉电源,用软纸把轴擦干净,再滴上缝纫机油,反复移动打印头把脏东西都洗出擦净,最后在干净的轴上滴上机油,移动打印头使其均匀分布,开机即可正常工作。</FONT><SPAN lang=EN-US><BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break"><o:p></o:p></SPAN></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><BR></SPAN><FONT size=3><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt">常见故障三:</SPAN><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">发出打印命令后,打印机无反应,系统提示打印机是否联机及电缆连接是否正常。</SPAN></FONT><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><BR></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>  原因:引起打印机不打印的故障原因有很多种,有打印机方面的,也有计算机方面的。以下分别进行介绍:</FONT><SPAN lang=EN-US><BR></SPAN><FONT size=3>  排除:</FONT></SPAN><FONT size=3><SPAN lang=EN-US style="FONT-FAMILY: 宋体; mso-fareast-font-family: 仿宋_GB2312; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">&nbsp;</SPAN><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">1.</SPAN><SPAN lang=EN-US style="FONT-FAMILY: 宋体; mso-fareast-font-family: 仿宋_GB2312; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">&nbsp;</SPAN></FONT><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>检查打印机是否处于联机状态。在大多数打印机上“<SPAN lang=EN-US>OnLine</SPAN>”按钮旁边都有一个指示联机状态的灯,正常情况下该联机灯应为常亮状态。如果该指示灯不亮或处于闪烁状态,则说明联机不正常,重点检查打印机电源是否接通、打印机电源开关是否打开、打印机电缆是否正确连接等。如果联机指示灯正常,关掉打印机,然后再打开,看打印测试页是否正常。</FONT><SPAN lang=EN-US><BR></SPAN><FONT size=3>  <SPAN lang=EN-US>2.</SPAN></FONT></SPAN><SPAN lang=EN-US style="FONT-FAMILY: 宋体; mso-fareast-font-family: 仿宋_GB2312; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>&nbsp;</FONT></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>检查打印机是否已设置为默认打印机。点击“开始<SPAN lang=EN-US>--</SPAN>设置<SPAN lang=EN-US>--</SPAN>打印机”,检查当前使用的打印机图标上是否有一黑色的小钩,然后将打印机设置为默认打印机。如果“打印机”窗口中没有使用的打印机,则点击“添加打印机”图标,然后根据提示进行安装。</FONT><SPAN lang=EN-US><BR></SPAN><FONT size=3>  <SPAN lang=EN-US>3.</SPAN></FONT></SPAN><SPAN lang=EN-US style="FONT-FAMILY: 宋体; mso-fareast-font-family: 仿宋_GB2312; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>&nbsp;</FONT></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>检查当前打印机是否已设置为暂停打印。方法是在“打印机”窗口中用右键单击打印机图标,在出现的下拉菜单中检查“暂停打印”选项上是否有一小钩,如果选中了“暂停打印”请取消该选项。</FONT><SPAN lang=EN-US><BR></SPAN><FONT size=3>  <SPAN lang=EN-US>4.</SPAN></FONT></SPAN><SPAN lang=EN-US style="FONT-FAMILY: 宋体; mso-fareast-font-family: 仿宋_GB2312; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>&nbsp;</FONT></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>检查计算机的硬盘剩余空间是否过小。如果系统硬盘可用空间低于<SPAN lang=EN-US>10MB</SPAN>则无法打印,检查方法是在“我的电脑”中用右键单击安装<SPAN lang=EN-US>Windows</SPAN>的硬盘图标,选择“属性”,在“常规”选项卡中检查硬盘空间,如果硬盘剩余空间低于<SPAN lang=EN-US>10MB</SPAN>,则必须清空“回收站”,删除硬盘上的临时文件、过期或不再使用的文件,以释放更多的空间。</FONT><SPAN lang=EN-US><BR></SPAN><FONT size=3>  <SPAN lang=EN-US>5.</SPAN></FONT></SPAN><SPAN lang=EN-US style="FONT-FAMILY: 宋体; mso-fareast-font-family: 仿宋_GB2312; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>&nbsp;</FONT></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>检查打印机驱动程序是否合适以及打印配置是否正确。在“打印机属性”窗口中“详细资料”选项中检查以下内容:在“打印到以下端口”选择框中,检查打印机端口设置是否正确,最常用的端口为“<SPAN lang=EN-US>USB</SPAN>口”,有些打印机也使用并口;如果不能打印大型文件,则应重点检查“超时设置”栏目的各项“超时设置”值,此选项仅对直接与计算机相连的打印机有效,使用网络打印机时则无效。</FONT><SPAN lang=EN-US><BR></SPAN><FONT size=3>  <SPAN lang=EN-US>6.</SPAN></FONT></SPAN><FONT size=3><SPAN lang=EN-US style="FONT-FAMILY: 宋体; mso-fareast-font-family: 仿宋_GB2312; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">&nbsp;</SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">检查计算机的<SPAN lang=EN-US>BIOS</SPAN>设置中打印机端口是否打开。<SPAN lang=EN-US>BIOS</SPAN>设置中,如果是并口打印机,使用端口应设置为“<SPAN lang=EN-US>Enable</SPAN>”,有些打印机不支持<SPAN lang=EN-US>ECP</SPAN>类型的打印端口信号,应将打印端口设置为“<SPAN lang=EN-US>Normal</SPAN>或</SPAN><SPAN lang=EN-US style="FONT-FAMILY: 宋体; mso-fareast-font-family: 仿宋_GB2312; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">&nbsp;</SPAN><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">ECP+EPP</SPAN></FONT><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>”方式;如果是<SPAN lang=EN-US>USB</SPAN>接口打印机,则应打开<SPAN lang=EN-US>USB</SPAN>设备接口。</FONT><SPAN lang=EN-US><BR></SPAN><FONT size=3>  <SPAN lang=EN-US>7.</SPAN></FONT></SPAN><SPAN lang=EN-US style="FONT-FAMILY: 宋体; mso-fareast-font-family: 仿宋_GB2312; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>&nbsp;</FONT></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>计算机中有病毒也会造成打印机不打印,此时需检查计算机中是否存在病毒,若有需要用杀毒软件进行杀毒。</FONT><SPAN lang=EN-US><BR></SPAN><FONT size=3>  <SPAN lang=EN-US>8.</SPAN></FONT></SPAN><SPAN lang=EN-US style="FONT-FAMILY: 宋体; mso-fareast-font-family: 仿宋_GB2312; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>&nbsp;</FONT></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>检查打印机驱动程序是否已损坏。可用右键单击打印机图标,选择“删除”,然后双击“添加打印机”,重新安装打印机驱动程序。</FONT><SPAN lang=EN-US><BR></SPAN><FONT size=3>  <SPAN lang=EN-US>9.</SPAN></FONT></SPAN><SPAN lang=EN-US style="FONT-FAMILY: 宋体; mso-fareast-font-family: 仿宋_GB2312; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>&nbsp;</FONT></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>打印机进纸盒无纸或卡纸,打印机墨粉盒、色带或碳粉盒是否有效,如无效,则不能打印。</FONT><SPAN lang=EN-US><BR></SPAN><FONT size=3>  <SPAN lang=EN-US>10.</SPAN>如果以上方法还不能排除问题,则有可能是电脑的并口已坏,需要维修电脑。</FONT><SPAN lang=EN-US><BR><BR></SPAN></SPAN><FONT size=3><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt">常见故障四</SPAN><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">:打印机安装正常,可以进行正常打印,但有时候打印会出现乱码。</SPAN></FONT><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><BR></SPAN><FONT size=3><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">  排除:首先检查数据线,如果打印机的数据线不支持双向通道就会出现这样的问题,换一条具有双向通道的数据线;可能是电脑中了病毒或是驱动程序版本太旧,需要重新安装驱动程序;</SPAN><SPAN lang=EN-US style="FONT-FAMILY: 宋体; mso-fareast-font-family: 仿宋_GB2312; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">&nbsp;</SPAN></FONT><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>打印机内存不够,如果一次打印的文件较大,会出现这样的问题,须扩充打印机的内存;字库还没有正确载入<SPAN lang=EN-US>,</SPAN>打印机也会出现这种现象。</FONT><SPAN lang=EN-US><BR><BR></SPAN></SPAN><FONT size=3><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt">常见故障五</SPAN><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">:打完一行后总是停一会再继续打下一行。</SPAN></FONT><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><BR></SPAN><FONT size=3><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">  排除:先看一下<SPAN lang=EN-US>BIOS</SPAN>设置中的“<SPAN lang=EN-US>Integrated</SPAN></SPAN><SPAN lang=EN-US style="FONT-FAMILY: 宋体; mso-fareast-font-family: 仿宋_GB2312; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">&nbsp;</SPAN><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">Peripherals</SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">”里面的“<SPAN lang=EN-US>Parallel</SPAN></SPAN><SPAN lang=EN-US style="FONT-FAMILY: 宋体; mso-fareast-font-family: 仿宋_GB2312; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">&nbsp;</SPAN><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">Port</SPAN><SPAN lang=EN-US style="FONT-FAMILY: 宋体; mso-fareast-font-family: 仿宋_GB2312; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">&nbsp;</SPAN><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">Mode</SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">”一项关于并口的设置,默认的“<SPAN lang=EN-US>SPP</SPAN>”速度很慢,一般将其改为<SPAN lang=EN-US>EPP</SPAN>或</SPAN><SPAN lang=EN-US style="FONT-FAMILY: 宋体; mso-fareast-font-family: 仿宋_GB2312; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">&nbsp;</SPAN><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">EPP+ECP</SPAN></FONT><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>模式比较好;然后检查打印机驱动程序是否安装正确,可以先卸载驱动程序,然后再重新安装一遍驱动;或检查一下打印机电缆是否有接触不良的情况;最后还有可能是电脑中了病毒,可以杀一遍毒。</FONT><SPAN lang=EN-US><BR></SPAN><FONT size=3>专家提示:病毒也会影响打印机的正常工作,它会导致电脑出现一些莫名其妙的错误,为了保证打印机的正常使用,要经常给电脑杀毒。</FONT><SPAN lang=EN-US><BR><BR></SPAN></SPAN><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>常见故障六</FONT></SPAN><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>:打印机中有纸,但打印机总提示缺纸</FONT><SPAN lang=EN-US><BR></SPAN></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>  排除:可能是因为打印机连线或接口损坏造成连接错误<SPAN lang=EN-US>,</SPAN>可以更换一条电缆,看问题是否能解决<SPAN lang=EN-US>;</SPAN>老版本的驱动程序或驱动程序中的错误所致,可以重新安装驱动程序或升级驱动程序(驱动程序在厂商的网站上一般都能找到),打印机传感器上灰尘堆积或打印机物理故障,需要清洁传感器或拿到厂商修理。</FONT><SPAN lang=EN-US><BR><BR></SPAN></SPAN><FONT size=3><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt">常见故障七</SPAN><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">:控制板上指示灯会发光,并向计算机返回一个报警信号</SPAN></FONT><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><BR></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>  原因:忘记关闭盖板、打印机在打印时取出纸张、打印纸张不合规格、送纸辊运转不正常、送纸路径有纸屑、碎纸等异物、装纸盘安装不正常、纸张质量不好<SPAN lang=EN-US>(</SPAN>过薄、过厚、受潮<SPAN lang=EN-US>)</SPAN>、纸张传感器出错等。</FONT><SPAN lang=EN-US><BR></SPAN><FONT size=3>  排除:出现卡纸现象时,不要急躁,打开前盖板,以进纸方向取纸。取纸时双手要平均用力、轻轻拽着被卡住的纸张,缓慢地将卡纸从打印机中取出来,切不可逆方向或反方向转动任何旋钮。在取出的过程中,应先关闭打印机电源。如果经常卡纸,就要检查进纸通道,清除输出路径的杂物,纸的前部边缘要刚好在金属板的上面;检查出纸辊是否磨损或弹簧松脱,压力不够,即不能将纸送入机器;出纸辊磨损,一时无法更换时,可用缠绕橡皮筋的办法进行应急处理,缠绕橡皮筋后,增大了搓纸摩擦力,能使进纸恢复正常。</FONT><SPAN lang=EN-US><BR><BR></SPAN></SPAN><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>常见故障八</FONT></SPAN><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>:打印机不能检测到墨水类型或打印出的字符模糊不清</FONT><SPAN lang=EN-US><BR></SPAN></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>  排除:先对打印头进行清洗(很多打印机的驱动程序里提供了清洗打印头命令,直接使用该命令即可),如果长时间没有使用打印机,就要多清洗几次,方法是把墨盒拆下来,在靠近打印头的地方用柔软的、吸水性较强的纸擦干净,如果还不能解决问题,那就可能是打印机驱动程序有问题,可把与打印机对应的驱动程序在重新装一遍,一般都能解决问题。</FONT><SPAN lang=EN-US><BR><BR></SPAN></SPAN><FONT size=3><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt">常见故障九</SPAN><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">:使用网络打印机时,无法打印或出现找不到网络打印机的提示。</SPAN></FONT><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><BR></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>  排除:先检查连接打印机的电脑上打印机设置是否正确,并确定该打印机已经共享,然后检察远程使用网络打印机的电脑上打印机设置是否正确。</FONT><SPAN lang=EN-US><BR><BR></SPAN></SPAN><FONT size=3><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt">常见故障十</SPAN><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">:打印机输出空白纸</SPAN></FONT><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><BR></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>  排除:对于喷墨打印机,打印空白页的故障大多是由于喷嘴堵塞、墨盒没有墨水等原因造成,应清洗喷头或更换墨盒,可按以下步骤排除:开始→设定→打印机→点选打印机,按右键→内容→工具,选择清洁打印头的项目,此时打印机就会自动清洁打印头,这需要几分钟的时间,完成之后请做打印机的自我测试,以检查墨水是否还足够,如果自我测试页中有一种或一种以上的颜色出不来,这是就需要更换新的墨盒。</FONT><SPAN lang=EN-US><BR><BR></SPAN></SPAN><FONT size=3><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt">常见故障十一</SPAN><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">:打印出的字符字迹偏淡</SPAN></FONT><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><BR></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>  排除:对于喷墨打印机,喷嘴堵塞、墨水过干、墨水型号不正确、输墨管内进空气、打印机工作温度过高都会引起本故障,应对喷头、墨水盒等进行检测维修;对于激光打印机,当墨粉盒内的墨粉较少,显影辊的显影电压偏低和墨粉感光效果差时,也会造成打印字迹偏淡现象。此时,取出墨粉盒轻轻摇动,使墨粉均匀分布,如果打印效果无改善,则应更换墨粉盒或调节打印机墨粉盒下方的一组感光开关,使之与墨粉的感光灵敏度匹配。<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><BR></SPAN><FONT size=3><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt">常见故障十二</SPAN><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt">:打印纸上出现有规律的污迹  </SPAN></FONT><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><BR></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-family: Arial; mso-bidi-font-size: 10.5pt"><FONT size=3>  排除:喷墨打印机重复出现脏污是由于墨水盒或输墨管漏墨所致;当喷嘴性能不良时,喷出的墨水与剩余墨水不能很好断开而处于平衡状态,也会出现漏墨现象;而激光打印机出现此类现象有一定的规律性,由于一张纸通过打印机时,机内的轧辊转过不止一圈,最大的感光鼓转过<SPAN lang=EN-US>2~3</SPAN>圈,送纸辊可能转过<SPAN lang=EN-US>10</SPAN>圈,当纸上出现间隔相等的污迹时,可能是由脏污或损坏的轧辊引起的。</FONT></SPAN><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-hansi-font-family: 宋体; mso-bidi-font-size: 10.5pt"><o:p></o:p></SPAN></P>
发表于 2006-11-10 21:25:00
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-SIZE: 12pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">5</SPAN><SPAN style="FONT-SIZE: 12pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">.捕捉下来的<SPAN lang=EN-US>AVl</SPAN>文件不能打开<SPAN lang=EN-US><?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312">1)</SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312">先检查硬盘空间是否足够,如果没有足够的空间装载<SPAN lang=EN-US>AVI</SPAN>文件,捕捉的<SPAN lang=EN-US>AVl</SPAN>文件无效,当然不能打开。<SPAN lang=EN-US><o:p></o:p></SPAN></SPAN></FONT></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312">2)</SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312">捕捉的<SPAN lang=EN-US>AVI</SPAN>文件长度建议不要超过<SPAN lang=EN-US>2GB</SPAN>,否则文件无效,不能打开。<SPAN lang=EN-US><o:p></o:p></SPAN></SPAN></FONT></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312">3)</SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312">如果<SPAN lang=EN-US>VGA</SPAN>卡档次不高,建议不要在<SPAN lang=EN-US>640~480</SPAN>格式下做动态捕捉,否则容易出现<SPAN lang=EN-US>AVl</SPAN>文件无效。<SPAN lang=EN-US><o:p></o:p></SPAN></SPAN></FONT></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312"><o:p><FONT size=3>&nbsp;</FONT></o:p></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-SIZE: 12pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">6</SPAN><SPAN style="FONT-SIZE: 12pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">.动态捕捉下来的<SPAN lang=EN-US>AVl</SPAN>文件占用太大的空间<SPAN lang=EN-US><o:p></o:p></SPAN></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312">1)</SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312">检查“视频格式”设置,如果选择的图像分辨率太大,比如超过“<SPAN lang=EN-US>320~<?:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" /><st1:chmetcnv w:st="on" UnitName="”" SourceValue="240" HasSpace="False" Negative="False" TCSC="0" Number="1">240<SPAN lang=EN-US><SPAN lang=EN-US>”</SPAN></SPAN></st1:chmetcnv><SPAN lang=EN-US>,则占用的空间会很大。<o:p></o:p></SPAN></SPAN></SPAN></FONT></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312">2)</SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312">没有选择压缩比高的压缩算法,如<SPAN lang=EN-US>H</SPAN>.<SPAN lang=EN-US>263</SPAN>或<SPAN lang=EN-US>M-JPEG</SPAN>等。<SPAN lang=EN-US><o:p></o:p></SPAN></SPAN></FONT></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-SIZE: 12pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">7</SPAN><SPAN style="FONT-SIZE: 12pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">.收到的电视节目模糊不清<SPAN lang=EN-US><o:p></o:p></SPAN></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt 9pt; TEXT-INDENT: -9pt; mso-list: l0 level1 lfo1; tab-stops: list 9.0pt"><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-family: 仿宋_GB2312"><SPAN style="mso-list: Ignore"><FONT size=3>1)</FONT><SPAN style="FONT: 7pt 'Times New Roman'">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312"><FONT size=3>检查天线是否有松脱或接触不良;<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt 9pt; TEXT-INDENT: -9pt; mso-list: l0 level1 lfo1; tab-stops: list 9.0pt"><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-family: 仿宋_GB2312"><SPAN style="mso-list: Ignore"><FONT size=3>2)</FONT><SPAN style="FONT: 7pt 'Times New Roman'">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312"><FONT size=3>申请加装有线电视;<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt 9pt; TEXT-INDENT: -9pt; mso-list: l0 level1 lfo1; tab-stops: list 9.0pt"><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-family: 仿宋_GB2312"><SPAN style="mso-list: Ignore"><FONT size=3>3)</FONT><SPAN style="FONT: 7pt 'Times New Roman'">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312"><FONT size=3>加装电视信号增强器。<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-SIZE: 12pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">8</SPAN><SPAN style="FONT-SIZE: 12pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">.电视卡录不到声音<SPAN lang=EN-US><o:p></o:p></SPAN></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312">1)</SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312">检查是否正确安装声卡,如果没有安装声卡,则不能录音。<SPAN lang=EN-US><o:p></o:p></SPAN></SPAN></FONT></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312">2)</SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312">检查设置中“捕捉音频”是否选好。<SPAN lang=EN-US><o:p></o:p></SPAN></SPAN></FONT></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-SIZE: 12pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">9</SPAN><SPAN style="FONT-SIZE: 12pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">.电视画面不动<SPAN lang=EN-US><o:p></o:p></SPAN></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312"><FONT size=3>从网上得知丽台<SPAN lang=EN-US>2000TV+</SPAN>与<SPAN lang=EN-US>TNT2</SPAN>系列的显示卡存在不兼容问题。经查找,发现电视卡上的光盘正好有丽台<SPAN lang=EN-US>TNT2Pro</SPAN>的<SPAN lang=EN-US>S320</SPAN>Ⅱ<SPAN lang=EN-US>Pro</SPAN>驱动程序,便将显示卡刷成丽台的<SPAN lang=EN-US>S320</SPAN>Ⅱ<SPAN lang=EN-US>Pro</SPAN>,装上<SPAN lang=EN-US>TV2000+</SPAN>光盘上的<SPAN lang=EN-US>S320</SPAN>Ⅱ<SPAN lang=EN-US>Pro</SPAN>的驱动程序,问题便可解决。<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-SIZE: 12pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">10.</SPAN><SPAN style="FONT-SIZE: 12pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">在观看或录制电视节目时延时或速度慢?<SPAN lang=EN-US><o:p></o:p></SPAN></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312"><FONT size=3>此时应检查机器配置,很可能是您机器配置达不到要求,可以在配置较高的机器上试用一下。<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
发表于 2006-11-10 21:27:00
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-SIZE: 14pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">键盘<SPAN lang=EN-US> <?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><o:p><FONT size=3>&nbsp;</FONT></o:p></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-SIZE: 12pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">常见故障一:键盘上一些键,如空格键、回车键不起作用,有时,需按无数次才输入—个或两个字符,有的键,如光标键按下后不再起来,屏幕上光标连续移动,此时键盘其它字符不能输入,需再按一次才能弹起来。<SPAN lang=EN-US> <o:p></o:p></SPAN></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  这种故障为键盘的“卡键”故障,不仅仅是使用很久的旧键盘,有个别没用多久的新键盘上,键盘的卡键故障也有时发生。出现键盘的卡键现象主要由以下两个原因造成的:一种原因就是键帽下面的插柱位置偏移,使得键帽按下后与键体外壳卡住不能弹起而造成了卡键,此原因多发生在新键盘或使用不久的键盘上。另一个原因就是按键长久使用后,复位弹簧弹性变得很差,弹片与按杆摩擦力变大,不能使按键弹起而造成卡键,此种原因多发生在长久使用的键盘上。当键盘出现卡键故障时,可将键帽拨下,然后按动按杆。若按杆弹不起来或乏力,则是由第二种原因造成的,否则为第一种原因所致。若是由于键帽与键体外壳卡住的原因造成“卡键”故障,则可在键帽与键体之间放一个垫片,该垫片可用稍硬一些的塑料<SPAN lang=EN-US>(</SPAN>如废弃的软磁盘外套<SPAN lang=EN-US>)</SPAN>做成,其大小等于或略大于键体尺寸,并且在按杆通过的位置开一个可使铵杆自由通过的方孔,将其套在按杆上后,插上键帽;用此垫片阻止键帽与键体卡住,即可修复故障按键;若是由于弹簧疲劳,弹片阻力变大的原因造成卡键故障,这时可特键体打开,稍微拉伸复位弹簧使其恢复弹性;取下弹片将键体恢复。通过取下弹片,减少按杆弹起的阻力,从而使故障按键得到了恢复。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-SIZE: 12pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">常见故障二:某些字符不能输入。<SPAN lang=EN-US> <o:p></o:p></SPAN></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  若只有某一个键字符不能输入,则可能是该按键失效或焊点虚焊。检查时,按照上面叙述的方法打开键盘,用万用表电阻档测量接点的通断状态。若键按下时始终不导通,则说明按键簧片疲劳或接触不良,需要修理或更换;若键按下时接点通断正常,说明可能是因虚焊、脱焊或金屑孔氧化所致,可沿着印刷线路逐段测量,找出故障进行重焊;若因金属孔氧化而失效,可将氧化层清洗干净,然后重新焊牢;若金属孔完全脱落而造成断路时,可另加焊引线进行连接。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-SIZE: 12pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">常见故障三:若有多个既不在同一列,也不在同一行的按键都不能输入。<SPAN lang=EN-US> <o:p></o:p></SPAN></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  可能是列线或行线某处断路,或者可能是逻辑门电路产生故障。这时可用<SPAN lang=EN-US>100MHz</SPAN>的高频示波器进行检测,找出故障器件虚焊点,然后进行修复。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-SIZE: 12pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">常见故障四:键盘输入与屏幕显示的字符不一致。<SPAN lang=EN-US> <o:p></o:p></SPAN></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  此种故障可能是由于电路板上产生短路现象造成的,其表现是按这一键却显示为同一列的其他字符,此时可用万用表或示波器进行测量,确定故障点后进行修复。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-SIZE: 12pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">常见故障五:按下一个键产生一串多种字符,或按键时字符乱跳。<SPAN lang=EN-US> <o:p></o:p></SPAN></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  这种现象是由逻辑电路故障造成的。先选中某一列字符,若是不含回车键的某行某列,有可能产生多个其他字符现象;若是含回车键的一列,将会产生字符乱跳且不能最后进入系统的现象,用示波器检查逻辑电路芯片,找出故障芯片后更换同型号的新芯片,排除故障。<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
发表于 2006-11-10 21:33:00
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-SIZE: 14pt; COLOR: red; FONT-FAMILY: 仿宋_GB2312">扫描仪<SPAN lang=EN-US> <?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="COLOR: red; FONT-FAMILY: 仿宋_GB2312"><o:p><FONT size=3>&nbsp;</FONT></o:p></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312"><FONT size=3>常见故障一:找不到扫描仪<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312"><FONT size=3>  相信这是最常见的故障。先用观察法看看扫描仪的电源及线路接口是否已经连接好,然后确认是否先开启扫描仪的电源,然后才启动计算机。如果不是,可以按<SPAN lang=EN-US>Windows</SPAN>“设备管理器”的“刷新”按钮,查看扫描仪是否有自检,绿色指示灯是否稳定地亮着。假若答案肯定,则可排除扫描仪本身故障的可能性。如果扫描仪的指示灯不停地闪烁,表明扫描仪状态不正常。这时候可以再重新安装最新的扫描仪驱动程序。同时,还应检查“设备管理器”中扫描仪是否与其他设备冲突<SPAN lang=EN-US>(IRQ</SPAN>或<SPAN lang=EN-US>I/O</SPAN>地址<SPAN lang=EN-US>)</SPAN>,若有冲突就要进行更改。记住,这类故障无非就是线路问题、驱动程序问题和端口冲突问题。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312"><FONT size=3>常见故障二:扫描仪没有准备就绪<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312"><FONT size=3>  打开扫描仪电源后,若发现<SPAN lang=EN-US>Ready(</SPAN>准备<SPAN lang=EN-US>)</SPAN>灯不亮,先检查扫描仪内部灯管。若发现内部灯管是亮的,可能与室温有关,解决的办法是让扫描仪通电半小时后关闭扫描仪,一分钟后再打开它,问题即可迎刃而解。若此时扫描仪仍然不能工作,则先关闭扫描仪,断开扫描仪与电脑之间的连线,将<SPAN lang=EN-US>SCSI ID</SPAN>的值设置成<SPAN lang=EN-US>7</SPAN>,大约一分钟后再把扫描仪打开。在冬季气温较低时,最好在使用前先预热几分钟,这样就可避免开机后<SPAN lang=EN-US>Ready</SPAN>灯不亮的<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312"><FONT size=3>现象。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312"><FONT size=3>常见故障三:扫描出来的画面颜色模糊<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312"><FONT size=3>  首先通过观察法看看扫描仪上的平板玻璃是否脏了,如果是的话请将玻璃用干净的布或纸擦干净,注意不要用酒精之类的液体来擦,那样会使扫描出来的图像呈现彩虹色。如果不是玻璃的问题,请检查扫描仪使用的分辨率是多少,如<SPAN lang=EN-US>300dpi</SPAN>的扫描仪扫<SPAN lang=EN-US>1200dpi</SPAN>以上的影像会比较模糊。因为<SPAN lang=EN-US>300dpi</SPAN>的扫描仪扫<SPAN lang=EN-US>1200dpi</SPAN>相当于将一点放至四倍大。另外,请检查显示器设置是否为<SPAN lang=EN-US>16bit</SPAN>色或以上。如果是扫描一些印刷品,有一定的网纹造成的模糊是可以理解的,处理方法可以用扫描仪本身自带的软件,也可以用<SPAN lang=EN-US>Photoshop</SPAN>等图像软件加以处理。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312"><FONT size=3>常见故障四:输出图像色彩不够艳丽<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312"><FONT size=3>  遇到这种故障,我们首先可以先调节显示器的亮度、对比度和<SPAN lang=EN-US>Gamma</SPAN>值。<SPAN lang=EN-US>Gamma</SPAN>值越高,感觉色彩的层次就越丰富。我们可以对<SPAN lang=EN-US>Gamma</SPAN>值进行调整。当然,为了求得较好的效果,你也可以在<SPAN lang=EN-US>Photoshop</SPAN>等软件中对<SPAN lang=EN-US>Gamma</SPAN>值进行调整,但这属于“事后调整”,我们可以根据扫好的照片的具体情况进行<SPAN lang=EN-US>Gamma</SPAN>值的调整。在扫描仪自带的软件中,如果是普通用途,<SPAN lang=EN-US>Gamma</SPAN>值通常设为<SPAN lang=EN-US>1.4</SPAN>;若是用于印刷,则设为<SPAN lang=EN-US>1.8;</SPAN>网页上的照片则设为<SPAN lang=EN-US>2.2</SPAN>。还有就是扫描仪在使用前应该进行色彩校正,否则就极可能使扫描的图像失真;此外还可以对扫描仪驱动程序对话框中的亮度<SPAN lang=EN-US>/</SPAN>对比度选项进行具体调节。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
发表于 2006-11-10 21:34:00
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>声卡<SPAN lang=EN-US> <?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>常见故障一:声卡无声。出现这种故障常见的原因有:<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  <SPAN lang=EN-US>1. </SPAN>驱动程序默认输出为“静音”。单击屏幕右下角的声音小图标(小嗽叭),出现音量调节滑块,下方有“静音”选项,单击前边的复选框,清除框内的对号,即可正常发音。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  <SPAN lang=EN-US>2. </SPAN>声卡与其它插卡有冲突。解决办法是调整<SPAN lang=EN-US>PnP</SPAN>卡所使用的系统资源,使各卡互不干扰。有时,打开“设备管理”,虽然未见黄色的惊叹号(冲突标志),但声卡就是不发声,其实也是存在冲突,只是系统没有检查出来。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  <SPAN lang=EN-US>3. </SPAN>安装了<SPAN lang=EN-US>Direct X</SPAN>后声卡不能发声了。说明此声卡与<SPAN lang=EN-US>Direct X</SPAN>兼容性不好,需要更新驱动程序。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  <SPAN lang=EN-US>4. </SPAN>一个声道无声。检查声卡到音箱的音频线是否有断线。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>常见故障二:声卡发出的噪音过大.出现这种故障常见的原因有:<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  <SPAN lang=EN-US>1. </SPAN>插卡不正。由于机箱制造精度不够高、声卡外挡板制造或安装不良导致声卡不能与主板扩展槽紧密结合,目视可见声卡上“金手指”与扩展槽簧片有错位。这种现象在<SPAN lang=EN-US>ISA</SPAN>卡或<SPAN lang=EN-US>PCI</SPAN>卡上都有,属于常见故障。一般可用钳子校正。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  <SPAN lang=EN-US>2. </SPAN>有源音箱输入接在声卡的<SPAN lang=EN-US>Speaker</SPAN>输出端。对于有源音箱,应接在声卡的<SPAN lang=EN-US>Line out</SPAN>端,它输出的信号<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>没有经过声卡上的功放,噪声要小得多。有的声卡上只有一个输出端,是<SPAN lang=EN-US>Line out</SPAN>还是<SPAN lang=EN-US>Speaker</SPAN>要靠卡上的跳线决定,厂家的默认方式常是<SPAN lang=EN-US>Speaker</SPAN>,所以要拔下声卡调整跳线。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  <SPAN lang=EN-US>3. Windows</SPAN>自带的驱动程序不好。在安装声卡驱动程序时,要选择“厂家提供的驱动程序”而不要选<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>“<SPAN lang=EN-US>Windows</SPAN>默认的驱动程序”如果用“添加新硬件”的方式安装,要选择“从磁盘安装”而不要从列表框中选择。如果已经安装了<SPAN lang=EN-US>Windows</SPAN>自带的驱动程序,可选“控制面板→系统→设备管理→声音、视频和游戏控制器”,点中各分设备,选“属性→驱动程序→更改驱动程序→从磁盘安装”。这时插入声卡附带的磁盘或光盘,装入厂家提供的驱动程序。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>常见故障三:声卡无法“即插即用”<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt"><FONT size=3><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt">1. </SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt">尽量使用新驱动程序或替代程序。<SPAN lang=EN-US><o:p></o:p></SPAN></SPAN></FONT></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  <SPAN lang=EN-US>2. </SPAN>最头痛的问题莫过于<SPAN lang=EN-US>Windows 9X</SPAN>下检测到即插即用设备却偏偏自作主张帮你安装驱动程序,这个驱动程序偏是不能用的,以后,每次当你删掉重装都会重复这个问题,并且不能用“添加新硬件”的方法解决。笔者在这里泄露一个独门密招:进入<SPAN lang=EN-US>Win9xinfother</SPAN>目录,把关于声卡的*<SPAN lang=EN-US>.inf</SPAN>文件统统删掉再重新启动后用手动安装,这一着百分之百灵验,曾救活无数声卡性命……当然,修改注册表也能达到同样的目的。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt"><FONT size=3><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt">3. </SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt">不支持<SPAN lang=EN-US>PnP</SPAN>声卡的安装(也适用于不能用上述<SPAN lang=EN-US>PnP</SPAN>方式安装的<SPAN lang=EN-US>PnP</SPAN>声卡):进入“控制面板”<SPAN lang=EN-US>/</SPAN>“添加新硬件”<SPAN lang=EN-US>/</SPAN>“下一步”,当提示“需要<SPAN lang=EN-US>Windows</SPAN>搜索新硬件吗?”时,选择“否”,而后从列表中选取“声音、视频和游戏控制器”用驱动盘或直接选择声卡类型进行安装。<SPAN lang=EN-US> <o:p></o:p></SPAN></SPAN></FONT></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt"><FONT size=3><SPAN lang=EN-US style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt">4. </SPAN><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt">检查声卡跳线是否正确。<SPAN lang=EN-US><o:p></o:p></SPAN></SPAN></FONT></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>常见故障四:播放<SPAN lang=EN-US>CD</SPAN>无声<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  <SPAN lang=EN-US>1. </SPAN>完全无声。用<SPAN lang=EN-US>Windows 98</SPAN>的“<SPAN lang=EN-US>CD</SPAN>播放器”放<SPAN lang=EN-US>CD</SPAN>无声,但“<SPAN lang=EN-US>CD</SPAN>播放器”又工作正常,这说明是光驱的音频线没有接好。使用一条<SPAN lang=EN-US>4</SPAN>芯音频线连接<SPAN lang=EN-US>CD</SPAN>-<SPAN lang=EN-US>ROM</SPAN>的模拟音频输出和声卡上的<SPAN lang=EN-US>CD</SPAN>-<SPAN lang=EN-US>in</SPAN>即可,此线在购买<SPAN lang=EN-US>CD</SPAN>-<SPAN lang=EN-US>ROM</SPAN>时会附带。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  <SPAN lang=EN-US>2. </SPAN>只有一个声道出声。光驱输出口一般左右两线信号,中间两线为地线。由于音频信号线的<SPAN lang=EN-US>4</SPAN>条线颜色一般不同,可以从线的颜色上找到一一对应接口。若声卡上只有一个接口或每个接口与音频线都不匹配,只好改动音频线的接线顺序,通常只把其中<SPAN lang=EN-US>2</SPAN>条线对换即可。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>常见故障五:<SPAN lang=EN-US>PCI</SPAN>声卡出现爆音<SPAN lang=EN-US> <?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  一般是因为<SPAN lang=EN-US>PCI</SPAN>显卡采用<SPAN lang=EN-US>Bus Master</SPAN>技术造成挂在<SPAN lang=EN-US>PCI</SPAN>总线上的硬盘读写、鼠标移动等操作时放大了背景<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>噪声的缘故。解决方法:关掉<SPAN lang=EN-US>PCI</SPAN>显卡的<SPAN lang=EN-US>Bus Master</SPAN>功能,换成<SPAN lang=EN-US>AGP</SPAN>显卡,将<SPAN lang=EN-US>PCI</SPAN>声卡换插槽上。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>常见故障六:无法正常录音<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  首先检查麦克风是否有没有错插到其他插孔中了,其次,双击小喇叭,选择选单上的“属性→录音”,看看各项设置是否正确。接下来在“控制面板→多媒体→设备”中调整“混合器设备”和“线路输入设备”,把它们设为“使用”状态。如果“多媒体→音频”中“录音”选项是灰色的那可就糟了,当然也不是没有挽救的余地,你可以试试“添加新硬件→系统设备”中的添加“<SPAN lang=EN-US>ISA Plug and Play bus</SPAN>”,索性把声卡随卡工具软件安装后重新启动。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>常见故障七:无法播放<SPAN lang=EN-US>Wav</SPAN>音乐、<SPAN lang=EN-US>Midi</SPAN>音乐<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  不能播放<SPAN lang=EN-US>Wav</SPAN>音乐现象比较罕见,常常是由于“多媒体”→“设备”下的“音频设备”不只一个,禁用一个即可;无法播放<SPAN lang=EN-US>MIDI</SPAN>文件则可能有以下<SPAN lang=EN-US>3</SPAN>种可能:<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  <SPAN lang=EN-US>1. </SPAN>早期的<SPAN lang=EN-US>ISA</SPAN>声卡可能是由于<SPAN lang=EN-US>16</SPAN>位模式与<SPAN lang=EN-US>32</SPAN>位模式不兼容造成<SPAN lang=EN-US>MIDI</SPAN>播放的不正常,通过安装软件波表的<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>方式应该可以解决<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  <SPAN lang=EN-US>2. </SPAN>如今流行的<SPAN lang=EN-US>PCI</SPAN>声卡大多采用波表合成技术,如果<SPAN lang=EN-US>MIDI</SPAN>部分不能放音则很可能因为您没有加载适当的波表音色库。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  <SPAN lang=EN-US>3. Windows</SPAN>音量控制中的<SPAN lang=EN-US>MIDI</SPAN>通道被设置成了静音模式。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="COLOR: red; FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>常见故障八:<SPAN lang=EN-US>PCI</SPAN>声卡在<SPAN lang=EN-US>WIN98</SPAN>下使用不正常<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></SPAN></P>
<P =Msonormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 仿宋_GB2312; mso-bidi-font-size: 10.5pt"><FONT size=3>  有些用户反映,在声卡驱动程序安装过程中一切正常,也没有出现设备冲突,但在<SPAN lang=EN-US>WIN98</SPAN>下面就是无法出声或是出现其他故障。这种现象通常出现在<SPAN lang=EN-US>PCI</SPAN>声卡上,请检查一下安装过程中您把<SPAN lang=EN-US>PCI</SPAN>声卡插在的哪条<SPAN lang=EN-US>PCI</SPAN>插槽上。有些朋友出于散热的考虑,喜欢把声卡插在远离<SPAN lang=EN-US>AGP</SPAN>插槽,靠近<SPAN lang=EN-US>ISA</SPAN>插槽的那几条<SPAN lang=EN-US>PCI</SPAN>插槽中。问题往往就出现在这里,因为<SPAN lang=EN-US>Windows98</SPAN>有一个<SPAN lang=EN-US>Bug</SPAN>:有时只能正确识别插在<SPAN lang=EN-US>PCI-1</SPAN>和<SPAN lang=EN-US>PCI-2</SPAN>两个槽的声卡。而在<SPAN lang=EN-US>ATX</SPAN>主板上紧靠<SPAN lang=EN-US>AGP</SPAN>的两条<SPAN lang=EN-US>PCI</SPAN>才是<SPAN lang=EN-US>PCI-1</SPAN>和<SPAN lang=EN-US>PCI-2</SPAN>(在一些<SPAN lang=EN-US>ATX</SPAN>主板上恰恰相反,紧靠<SPAN lang=EN-US>ISA</SPAN>的是<SPAN lang=EN-US>PCI-1</SPAN>),所以如果您没有把<SPAN lang=EN-US>PCI</SPAN>声卡安装在正确的插槽上,问题就会产生了。 </FONT></SPAN></P>
发表于 2006-12-11 23:46:10
人真好~~~好好看看再说
发表于 2006-12-12 13:23:10
谢谢楼主,收下来慢慢学~~~~~~
发表于 2006-12-12 20:37:26
哎 只有慢慢看了太多啊 谢谢!
发表于 2006-12-19 17:39:23
二零零六年十二月十八日,是我中心成立三周年暨成为《国家信息产业
部》电脑芯片级教育认证基地二周年.为感谢广大学员及社会各界的大力支
持,凡2006年12月8日至2007年1月31日期间报名的学员,可享受优惠;学员
如因时间及其它原因不能在年前学习,可预先报名,年后学习,费用按优惠
期间费用计算.
优惠项目
学习科目........原价.....校庆特优价....老学员优惠价
主板维修班......1400.......988............918
硬盘初级班......980........668............618
显示器维修班....1580.......998............928
MP3维修班.......1200.......588............518
打印机维修班....1680.......1268...........1168
笔记本维修班....3800.......2288...........1988
对外感言
   在社会各界及广大学员的关心和支持下,翔达中心在过去的三年里不断推陈
出新,不断改进教学、服务质量,不断拓宽办学思路,推出一个又一个高品
质的IT教育产品,赢得了良好的声誉.
  在过去的三年里,翔达中心充分认识到:维修水平作为学员评定学员是
否合格的最重要的一环而且是就业的第一要素.我们相信:优秀的翔达人会
创造良好的学习氛围,良好的学习氛围意味着更注重学习、更出色的学员.
为此,我们将为学员推出各项实习课程.让学员充分利用好时间、共同促进
、共同提高.
   在今后的日子里,翔达中心将更加努力地为社会服务.为此,翔达中心在原
有的课程设置的基础上,还将推出各项适合学员焊接能力提高、理论水平提
高、适应IT发展的产品组合;推出各项适合在校学生的课程和芯片级讲座以
及提高学员维修操作水平的课程;努力改进咨询服务,进一步强化和完善网
上留言与热线电话及在线QQ 为主的咨询平台.
   翔达中心知道如何设计人生目标并使人生目标更健康、更有意义、更成功的
计划;我们也认识到最初维修理论、维修焊接基础在帮助我们的学员达到维
修技术精通的过程中起着关键的作用,我们愿意为学员量身定制学习计划,
并为他们开店、工作发展方向提供全程服务和技术支持.
.................少数人的技术!
...................一个能学到真正技术的地方!
.....................一个100%无技术保留的地方!
          请相信,选择翔达,就是选择成功!
中心地址:广州市天河石牌西路13号六楼整层(太平洋二期后面)
客服电话:020-87567006 61081261  培训网址:www.xd168.cn
客服传真:020-31899327            维修网址:www.gzkdpc.com
在线QQ:  41065830                官方网址:www.gdheace.org
邮箱:heace@gdheace.org
手机:13556008257
