VirtualBox最早是德国一家软件公司InnoTek所开发的虚拟系统软件,后来被Sun收购,改名为Sun VirtualBox,在Sun被Oracle收购后现改名为Oracle VirtualBox.因为他是开源的,不同于VM,而且功能强大,可以在 Linux/Mac 和 Windows 主机中运行, 并 支持在其中安装 Windows (NT 4.0、2000、XP、Server 2003、Vista)、DOS/Windows 3.x、Linux (2.4 和 2.6)、OpenBSD 等系列的客户操作系统.假如你曾经有用过虚拟机软件的经历的话,相信使用 VirtualBox 不在话下。即便你是一个新手,也没有关系。VirtualBox 提供了详细的文档,可以助你在短期内入门。
Changes in VirtualBox 3.2.12 (2010-11-30):
* VMM: fixed rare host crash when running 64-bit guests on 32-bit hosts (bug #7577)
* VMM: fixed host reboots under rare circumstances due to NMIs triggered by active performance counters (Linux hosts in non-VT-x/AMD-V mode only; bug #4529)
* VMM: fixed out of memory guru meditation for large memory guests (bug #7586)
* VMM: fixed a guru meditation related to large pages
* VMM: use new VT-x feature to keep the guest from hogging the CPU
* Snapshots: implemented deleting the last remaining snapshot while the VM is running
* GUI: perform the checks for exceeding the size limit of the host file system and for broken asynchronous I/O on older Linux kernels with ext4 / xfs file systems not only when starting the VM from scratch but also when starting from a saved state
* NAT: fixed memory leak (3.2.0 regression; bugs #6918, #7353)
* Networking: fixed VM reset handling in e1000
* VRDP: fixed rare crash in multimonitor configuration
* Display: fixed occasional guest resize crash
* Mouse: don't send relative mouse events together with absolute mouse events (3.2.10 regression; bug #7571)
* Keyboard: fixes for the USB keyboard emulation; fixes for Koran keyboards
* Serial: don't hang if the host device would block during open (bugs #5756, #5380)
* Serial: fixed modem status lines (Linux hosts only; bug #812)
* Graphics: Horizontal resolutions are no longer restricted to a multiple of 8 pixels (bug #2047; requires Guest Additions update).
* USB: fixed a crash with older Linux kernels and non-ASCII characters in device strings (Linux hosts only; bug #6983, #7158, #7733; version 3.2.8 contained an incomplete fix)
* USB: fixed a crash under rare circumstances (bug #7409; Windows hosts only)
* iSCSI: respond to NOP-In requests from the target immediately to avoid being disconnected if the guest is idle
* 3D support: fixed a crash under certain circumstances (bug #7659)
* 3D support: fixed crashes for GLUT based apps (bug #6848)
* 3D support: added missing GLX 1.3 functionality (bugs #7652, #7195)
* 2D Video acceleration: fixed potential deadlock when saving the VM state (bug #4124)
* Windows hosts: another fix for BSODs under certain circumstances in VBoxNetFlt.sys (bug #7601)
* Solaris hosts: fixed host USB DVD drive detection
* Mac OS X hosts: fixed swapped keys for certain ISO keyboard types (bug #2996)
* Linux hosts: added link state handling for TAP devices needed for proper operation with bridged networking on kernels 2.6.36 and above (bug #7649)
* Linux hosts/guests: Linux 2.6.37 fixes
* Linux Additions: properly compile the vboxvideo module if DKMS is not installed (bug #7572)
* Linux Additions: fixed a memory leak when accessing non-existing files on a Shared Folders (bug #7705)
* Windows Additions: skip none-mapped user accounts when enumerating user accounts for VM information
下载:VirtualBox 3.2.12
