MPC(Media Player Classic)是一个免费的WMP(Windows Media Player)外壳程序.它非常小巧,只需一个主程序即可.外观酷似 WMP6.4,但它的功能却是后者远不能及的.MPC 不仅可以播放所有WMP支持的格式,甚至连GIF动画都不放过,而且效果很不错.如果您已经安装了Real、QuickTime、Flash**,那么 这些这些类型的媒体也能使用它来播放.
Changes in Media Player Classic Home Cinema v1.5.0.2827 - 31 January 2011:
NEW : Added new options to always default to external subtitles, ignore embedded subtitles and to set the autoload subtitle paths
NEW : Added support for "in24", "fl64", 8-bit "sowt", "IMA4" and "NONE" audio (old QuickTime PCM)
NEW : Added support for "in24", "in32", "fl32", "fl64" (both big-endian and little-endian) in .mov files
NEW : Ticket #784, Enable ctrl+A in the MediaInfo window
NEW : [DVB] LCN support, added EPG current event information, offset parameter for scanning channels, added channel encryption detection for DVB-t during scan
NEW : Added ignore encrypted channels checkbox during DVB scan
NEW : Armenian translation
CHANGED: Updated FFmpeg
CHANGED: Updated MediaInfoLib to v0.7.39
CHANGED: Updated ZenLib to v0.4.17
CHANGED: Updated Little CMS to v2.1
CHANGED: Updated libpng to v1.4.5
CHANGED: Updated libogg to v1.2.2
CHANGED: Updated libvorbis to v1.3.2
CHANGED: Cleaned up and optimized code for QT PCM, small corrections in MP4Splitter
CHANGED: DVB: the current channel audio stream is memorized and selected by default each time the channel is switched back
CHANGED: Removed DSM Converter (use the legay branch if you need this feature)
CHANGED: Removed RoQ splitter/decoder (same as above)
FIXED : Ticket #52, [playlist] shuffle is broken
FIXED : Ticket #78, ESC key cannot be assigned to other actions
FIXED : Ticket #293, giving "remember last window size" a meaning
FIXED : Ticket #564, EVR Sync enabled when it shouldn't be
FIXED : Ticket #627, Don't create the "AppData\Roaming\Media Player Classic" folder if the "Remember items" in playlist is disabled
FIXED : Ticket #628, Enable ctrl+A in Player-->Keys page
FIXED : Ticket #647, Weird "keys" listed
FIXED : Ticket #650, Non-media entry in playlist halts playback
FIXED : Ticket #651, Make EVR CP stats graph smaller
FIXED : Ticket #652, Escape key on certain form causes form to collapse
FIXED : Ticket #655, Crash with some BBC-HD samples
FIXED : Ticket #678, Remember last window size NOT working and mpc-hc.ini
FIXED : Ticket #698, VMR-9 (Renderless) + pixel shaders crashes
FIXED : Ticket #699, fix EAC3 mediatype and string
FIXED : Ticket #712, Audio renderer menu problem with Haali splitter after r2339
FIXED : Ticket #724, Frequency range and bandwidth value are currently not taken into account when doing a scan
FIXED : Ticket #753, DVB-T, internal MPEG-2 filter & wrong aspect ratio
FIXED : Ticket #775, Default options of DVD/OGM Preferred language should be "Default" not "English"
FIXED : Ticket #776, Mouse pointer hovering over window/video should be normal, not hand
FIXED : Ticket #778, Playlist interface problem
FIXED : Ticket #782, VMR-7 & 9 filter names misspelled
FIXED : Ticket #791, Change the cursor behavior
FIXED : Ticket #796, MPC HC window doesn't stay snapped to desktop corners
FIXED : Ticket #809, Resize-arrows no longer appear with caption hidden
FIXED : Ticket #889, [DVB] <enter> keypress in channel list makes whole pane grey
FIXED : Ticket #891, [DVB] clicking empty slot in channel list causes small playback hiccup
FIXED : Ticket #895, [DVB] some characters don't show in EPG OSD
FIXED : DVB Screen sizing: takes into account the TV Navigation panel
FIXED : Workaround to avoid madVR renderer freezing when switching DVB channels
FIXED : Bandwidth value was hardcoded to 8MHz when doing a scan or switching channels. The value entered in scan is now saved in the configuration
下载:Media Player Classic Home Cinema 1.5.0.2827
