nginx(发音同engine x)是一款由俄罗斯程序员Igor Sysoev所开发轻量级的网页服务器、反向代理服务器以及电子邮件(IMAP/POP3)代理服务器。起初是供俄国大型的门户网站及搜索引擎 Rambler(俄语:Рамблер)使用。此软件BSD-like协议下发行,可以在UNIX、GNU/Linux、BSD、Mac OS X、Solaris,以及Microsoft Windows等操作系统中运行。
http://nginx.org/download/nginx-1.0.1.tar.gz (linux)
http://nginx.org/download/nginx-1.0.1.zip (win)
Changes with nginx 1.0.1 03 May 2011
*) Change: now the "split_clients" directive uses MurmurHash2 algorithm
because of better distribution.
Thanks to Oleg Mamontov.
*) Change: now long strings starting with zero are not considered as
false values.
Thanks to Maxim Dounin.
*) Change: now nginx uses a default listen backlog value 511 on Linux.
*) Feature: the $upstream_... variables may be used in the SSI and perl
modules.
*) Bugfix: now nginx limits better disk cache size.
*) Bugfix: a segmentation fault might occur while parsing incorrect
IPv4 address; the bug had appeared in 0.9.3.
*) Bugfix: nginx could not be built by gcc 4.6 without --with-debug
option.
*) Bugfix: nginx could not be built on Solaris 9 and earlier; the bug
Thanks to Dagobert Michelsen.
*) Bugfix: $request_time variable had invalid values if subrequests
were used; the bug had appeared in 0.8.47.
Thanks to Igor A. Valcov. |
